P0269 & P0284 - Ford Powerstroke Diesel Forum
post #1 of 26 Old 06-07-2008, 06:30 AM Thread Starter
scheidt27's Avatar
P0269 & P0284
I ran a cylinder contribution test this morning and these codes came up. truck was fully warmed up. Not sure how serious it is, I dont know anything about injectors. Im changing the oil right now. I had about 4k on Rotella 5-40 and now im aswitching to Delo 15-40. I though I read somewhere that the condition of your oil has alot to do with these types of things, hoping its just that!! Well I changed it and I still got the codes. I drove the truck around for about a half hour before I ran the test again. The truck runs perfectly. Any suggestions??
P0269 Cylinder 3 Contribution/Balance Fault
P0284 Cylinder 8 Contribution/Balance Fault
2002 F250
Beans Diesel Performance Tunes
All Supporting Mods
scheidt27 is offline
post #2 of 26 Old 06-07-2008, 09:41 AM Thread Starter
scheidt27's Avatar
anyone have any ideas???
2002 F250
All Supporting Mods
post #3 of 26 Old 06-07-2008, 09:45 AM
ADMIN AND TECH
SCUFFY828's Avatar
you said at the end its running perfectly , is it still skipping
ITS STOCK
SCUFFY828 is offline
post #4 of 26 Old 06-07-2008, 09:49 AM Thread Starter
scheidt27's Avatar
yup, truck runs perfectly as far as I can tell. It still pulls the same codes though. I have done the test a few times this morning now. What do you mean by skipping?? Thanks
2002 F250
All Supporting Mods
post #5 of 26 Old 06-07-2008, 09:53 AM
sldghamr's Avatar
i have been running Delo 15-40 for 100k miles now, zero problems on my rig.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #6 of 26 Old 06-07-2008, 09:59 AM Thread Starter
scheidt27's Avatar
Yea i was hoping the oil is what was causing the codes for my injectors, no such luck. The truck is quieter with the Delo though, less chattering
2002 F250
All Supporting Mods
post #7 of 26 Old 06-07-2008, 10:08 AM
TennesseeDuck's Avatar
I have the very same codes for the same cyl's on my 99, I am hoping a oil change does it for me too. Mine runs fine most of the time, every now and then it will idle rough but its not a everyday thing. I think I'll keep my eye on this thread just in case a oil change don't do it for me either. No other codes at all? I also pulled up a code for the icp P1211 and 2 codes for ebp P1670 & P0470. One of these days it will quit raining when I can do something to correct these issues.
Ed
___________________________
1999 F-350 SC Long Bed 4x4 7.3L 6-speed
2/99 Build Date
AFE Stage 2 Intake
Valair Ceramic Clutch
5" Miter Stacks
DP Tuner (no start, stock, hi-idle, 80 tow, 80 econo, 140 extreme)
Foil Delete
Isspro Gauges
XDP X-Wheel
Wifes Ride
2004 F-250 Crewcab 6.0 Lariat FX4
SCT
TennesseeDuck is offline
post #8 of 26 Old 06-07-2008, 10:10 AM Thread Starter
scheidt27's Avatar
mine will pull the P1211 and the one for the AIH Delete as well. These are normal for me though since I have the AIH delete and the chip causes the P1211
2002 F250
All Supporting Mods
post #9 of 26 Old 06-07-2008, 10:25 AM
I didn't know the dp tuner would cause the 1211, thats a relief. Thanks. You do know the engine oil has to be above a certain temp to run the contribution test don't ya. I figured you did since you said you had it warmed up but I had to take mine for a short drive to get the oil temp warm enough but I still pulled the cyl codes.
Ed
2/99 Build Date
AFE Stage 2 Intake
5" Miter Stacks
Foil Delete
Isspro Gauges
XDP X-Wheel
Wifes Ride
SCT
post #10 of 26 Old 06-07-2008, 10:56 AM
Cobra 19 & 54's Avatar
where can you get a list and definition of the codes a ECU will throw out?
Cobra 19 & 54 is offline
