  #11 (permalink)
Old 12-30-2005, 05:03 PM
Mike OB Mike OB is offline
In the dark?
3M makes a plastic polish and a plastic cleaner, I think Napa also has something like it also. If you polish your headlights with it you can gain about half the light back. I believe by adding a ground at each headlight on my daughters is what made it get brighter. I had bought the real bright bulbs from JCWhittney and installed them, that is what melted my daughters plugs. You can add a ground wire without replaceing the plugs, just cut off the insulation and solder an extra wire to the ground wire and put an eyelet on it and bolt it to a clean (NO PAINT) spot of metal right at the headlight - if not sure which wire is ground, turn on lights and back prob three wire socket. One will be hot with low beam and one will have power with high beam - the one with no power is the ground. Good luck and happy New Year Mike OB
  #12 (permalink)
Old 12-31-2005, 07:51 AM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
I'm glad my truck has the kentucky truck plant decal on the windshield!
