Winter storage - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-04-2013, 05:44 PM Thread Starter
Quoted: 2 Post(s)
Winter storage
Being new to diesels, I need some advise on winter storage. The truck is the tow vehicle for our 5th wheel and both will go into outdoor storage over the winter. What do I need to do to store the truck? I will do the obvious - fill the tank to reduce condensation, remove the batteries and put on a battery maintainer, cover the truck. Any other suggestions??
inspectorCSS is offline
post #2 of 3 Old 09-04-2013, 06:56 PM
chrispaine's Avatar
All I can think of off the top of my head is use an anti-gel in the fuel, make sure your antifreeze is up to par, and make sure rodents cannot get into your air filter, maybe even some rat poison to keep them from eating wires, the valley seems like it would be a cozy place for field mice.
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #3 of 3 Old 09-04-2013, 07:03 PM
Macon's Avatar
Also, if you can find a station with real diesel, that would be best. The bio-stuff readily absorbs moisture. Spray it down with some permethrin to keep the bugs out, rat poison for furry critters. Put it on blocks to save the tires. Fire it up once every couple weeks to keep seals from drying out.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
