AFE air filters good or bad? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-04-2013, 09:22 AM Thread Starter
early99psd's Avatar
Quoted: 13 Post(s)
I have been looking for a while and can't seem to get an answer, so my question is does the afe oiled air filter do a better job at filtering than k&n? I had the stage 2 intake on my truck but took it off and did the 6637. I was worried about dusting the turbo. Is the afe better than the 6637 as far as a CAI is concerned?
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is online now
post #2 of 14 Old 09-04-2013, 10:24 AM
I had an AFE system on my truck for about 70,000 miles. Most of those miles was using the standard oiled filter before putting a proguard 7 on. I drive in some dusty conditions and never saw any signs of dust in the system using either filter. I recently put the 6637 filter on because I wanted sense of mind that the filtering was even better.
99' Powerstroke is offline
post #3 of 14 Old 09-04-2013, 12:04 PM
rascal's Avatar
I currently have an AFE II Pro Dry S with a pre-filter.
So far so good!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #4 of 14 Old 09-04-2013, 12:14 PM
Raul@Stealth Automotive's Avatar
I dont think their has ever been a test to see if the AFE unit filters better than the K&N unit so pretty much everything anyone is going to say is just personal opinion... My personal opinion is that the AFE is better.... If it were me i would go with the Pro Dry S
Raul@Stealth Automotive is offline
post #5 of 14 Old 09-04-2013, 12:21 PM Thread Starter
early99psd's Avatar
Quoted: 13 Post(s)
How long have you had it on the truck? I liked the afe before but I was concerned about to much getting past the filter. Do the dry filters do a better job than the oiled ones?
post #6 of 14 Old 09-05-2013, 01:59 AM
I have an AFE stage 2 intake oiled filter and it works just fine. Pulled the filer off before a road trip a few weeks ago to brush off some dust & debris from the outside and you can eat off of the inside. A K&N filter of similar design will work just as well - it is the drop in filter for the stock housing that has fitment issues. Even the best system will do damage if it is not installed properly. There is nothing guaranteed fail-safe against ****pit failure on an install
hydroman is offline
post #7 of 14 Old 09-05-2013, 02:43 AM
Quoted: 48 Post(s)
there has absolutely been testing done between AFE and K&N (and S&B and the popular large paper filters)
AFE is the best high flow/performance filter out there. the 7 layer is the best filtering giving up a little flow to the 5 layer.
The paper filters filter best giving up some flow obviously.
I wouldn't let a K&N anywhere near one of my trucks. Personally I wouldn't let an S&B anywhere near one of my trucks
drunk on diesel is offline
post #8 of 14 Old 09-05-2013, 08:19 AM
Powerstroke Junkie
NCHornet's Avatar
My silicon reports have been the lowest with the Ford AIS, between the AFE and the K&N the AFE results were much lower. I see numbers below 5 with the Ford AIS intake, the AFE were always under 7, besides one number 8 that I received one time after many miles off road. The K&N had numbers above 12 and was removed really quick. I hope this helps someone.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #9 of 14 Old 09-05-2013, 08:23 AM Thread Starter
early99psd's Avatar
Quoted: 13 Post(s)
I like the afe setup but was concerned about the filter not being as good as it should, that's why I went to the 6637. I am now thinking of going back to the afe setup and using the pro dry s. Any thoughts?
post #10 of 14 Old 09-06-2013, 05:25 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
The best filters are either the Big Donaldson used in the Tymar intake or in the Ford AIS..only filter kits we will sell.
CT Performance, Inc. is offline
