01 F 350 7.3 turbo shut off - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-04-2013, 08:01 AM Thread Starter
Lilsinkko's Avatar
Ok I need some help I have a 01 F350 from my under standings the turbo cannot be shut off. Is there any after market turbo that could replace the stock one that would be able to be shut down? Please help me out.
Lilsinkko is offline
post #2 of 14 Old 09-04-2013, 08:09 AM
dieselflash's Avatar
And why exactly would you want to shut your turbo down?
Ford Master Diesel Tech
dieselflash is offline
post #3 of 14 Old 09-04-2013, 08:35 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
That's a humdinger of a first post
Turbos can't be shut off as they're mechanical. There isnt going to any mod or turbo that has a switch to shut them off.
Exhaust gasses expelled from the engine turn the turbo's turbine on the "hot" side. From there is a shaft that is directly connected to the "cold" side turbine wheel which pulls fresh air from your intake.
Turn the engine on, the turbo spools and is "on". Turn the engine off, the turbo can be heard winding down to a stop (turbo "off").
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #4 of 14 Old 09-04-2013, 08:40 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Oh geez not another one of these run without turbo? OP read that im sure you will get an answer on that thread
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #5 of 14 Old 09-04-2013, 08:48 AM
jesilvas's Avatar
Quoted: 3 Post(s)
You are correct; turbos can not be shut down.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 14 Old 09-04-2013, 09:25 AM
I've got an automatic shut down on my turbo, its called an ignition switch.
post #7 of 14 Old 09-04-2013, 10:36 AM
CSIPSD's Avatar
aw how cute. Someone wants to blow smoke!
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #8 of 14 Old 09-04-2013, 11:16 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1074 Post(s)
Feedback Score: 6 reviews
Hmmmm ok.... Definitely a very interesting first post by the OP.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #9 of 14 Old 09-04-2013, 11:32 AM
Chapter Director
Quoted: 5 Post(s)
Theoretically you could rig the wastegate to be open the whole time causing the turbo to "turn off" in a sense. but what that could cause is beyond anything i would even consider trying
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 14 Old 09-19-2013, 09:30 AM Thread Starter
Lilsinkko's Avatar
I am just trying to find truth behind this hole subject I have heard so many diffrent thing about 6.0 having the waste gate and being able to run a switch. I was just wondering how it was done and if there was truth behind it.
