New to diesels, do I need gauges? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-04-2013, 05:04 AM Thread Starter
Hi, I just bought a 2002 f250 last week. It has 180000 miles and it came with a superchips 1705(three tune) tuner. Right now it is set on the high performance mode because I'm assuming that will get me the most fuel efficiency. However, I have read that I should probably be running at least an EGT gauge and a tranny temp gauge. I am not towing anything heavy and I don't live in high elevation. I may be pulling my jeep on a flat bed at some point though. Should I be buying some gauges? If so, what marks should I be staying under? Thanks in advance!
Tank250 is offline
post #2 of 10 Old 09-04-2013, 07:03 AM
CSIPSD's Avatar
Yes. Period.
Pyro, Boost, Trans temp and Fuel pressure are the top 4...
Isspro Ev-2 is the best quality gauge you can buy.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 10 Old 09-04-2013, 01:44 PM
heisman01's Avatar
Quoted: 54 Post(s)
I got my truck with the same tuner originally, tow performance gave me a lot better mpg.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #4 of 10 Old 09-04-2013, 02:03 PM
Justin@DP-Tuner's Avatar
Quoted: 63 Post(s)
Gauges are never a bad idea. Once you start adding power, they are vital.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #5 of 10 Old 09-04-2013, 04:12 PM
blue72's Avatar
Feedback Score: 5 reviews
As already said gauges are always a good idea. Where do you live, are there any hills or mountains around? If so, I would not tow anything with the tunes loaded in the truck until I got some gauges. If you need to tow something before you get gauges, I would go back to stock.
2000 F350 XLT SCLB 4x4
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
Stewart Warner Gauges
blue72 is offline
post #6 of 10 Old 09-04-2013, 06:13 PM
Tugs's Avatar
If you add power definitely. The digital gauges are the easiest to install I went with the DP Tuner Infinity because of the digital gauges. It is also a diagnostic computer and a PCM programmer. Good stuff!!!
2003 7.3 Crew Cab FX4 Mods DIY Intake with AFE BHAF, 4" SS Diamond Eye exhaust, rancho 9000 shocks, 17" chrome Rockstars, Nitto Terragrappler's, Pioneer Headunit, Kicker DS68 door and rear speakers, 8" amplified bazooka tube,Backup camera, factory Ford chrome oval step bars, 08 Super Duty tailgate, 08 tow mirror's, DP tuner Infinity, F5 & CEI hub
Tugs is offline
post #7 of 10 Old 09-04-2013, 08:06 PM Thread Starter
I live in northwest Missouri. Not a lot of hills and I won't be towing anything for a while. Heaviest ill be pulling is my jeep on a flat bed. By then I should have gauges. This weekend I am driving to Columbia (3.5 hours) and I was just wondering if I was going to need gauges but I have had multiple guys tell me no in person. I imagine if the truck has 180k miles without gauges it will probably live another 400 without them...
Tank250 is offline
post #8 of 10 Old 09-05-2013, 12:34 AM
If you run hot tunes with no gauges you won't be running for long, even on flat ground if you hot rod it. I have intake and exhaust mods and even in a relatively mild tune I can see 1K* if I get on it for any time at all.
hydroman is offline
post #9 of 10 Old 09-05-2013, 07:22 AM
Powerstroke Junkie
NCHornet's Avatar
Gauges should be the first thing you do, this allows you to derive a good baseline so you can see how future mods affect the powertrain. Even a stock truck that never tows can still benefit from having gauges. I would also look at getting some better tunes than the old 1705 tuner.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #10 of 10 Old 09-10-2013, 08:26 PM
ScottyP5947's Avatar
Quoted: 2 Post(s)
Stay within the limits that superchips recommends for the setting you are running, and you may be ok. It's not all brimstone and fire if you opt to run a tuner without gauges, just be sensible or it can be! As for the superchips tune, I used to run it and it wasn't bad at all. The tow performance tune was the economy winner for me too. I got some PHP tunes and I like them, it was better than the canned tunes indeed.
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
