Converting E99 to later 7.3 - Ford Powerstroke Diesel Forum
post #1 of 46 Old 09-03-2013, 09:50 AM Thread Starter
Question Converting E99 to later 7.3
Can anyone tell me what all is needed to convert an e99 to a later 99 7.3. Also what would the total cost be. I'm sure that several members have already did this.
Thanks
COP-OUT is offline
post #2 of 46 Old 09-03-2013, 12:09 PM
Quoted: 816 Post(s)
Up pipes, turbo, pedestal, intake manifolds, spider pipe, a few boots.
I've got some of the parts to do this if you like?
Corey@CNCFAB is offline
post #3 of 46 Old 09-03-2013, 12:10 PM
schlutzer's Avatar
Quoted: 18 Post(s)
PCM
IDM
Turbo
Intake spider
Intake manifolds
Boots between spider and manifolds
Up pipes
Injectors
Turbo pedestal
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 46 Old 09-03-2013, 12:12 PM
Quoted: 816 Post(s)
Originally Posted by schlutzer View Post
PCM
IDM
Turbo
Intake spider
Intake manifolds
Up pipes
Injectors
Turbo pedestal
You don't need the PCM or IDM.
post #5 of 46 Old 09-03-2013, 12:39 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I said those two things for a reason, minor but still.
PCM because you get a cruise control light (lol)
And IDM because I did notice an immediate difference putting it in my truck. I've read they put out the same voltage but they have different part numbers so SOMETHING has to be different. I've actually had all 3 hooked up to my truck at one point or another and you do notice a SOTP change.
That and it's technically part of the E99 conversion if you want to be thorough
Also to the OP, don't upgrade the PCM because somebody told you yours can't be chipped, or isn't as good chipped. I know DP, and probably the other tuners have figured out the E99 tuning years ago. I upgraded mine because I did a manual swap at the same time.
post #6 of 46 Old 09-03-2013, 01:49 PM
mxracer511's Avatar
Quoted: 4 Post(s)
Send a message via AIM to mxracer511 Send a message via Yahoo to mxracer511
Also front wheel bearings and rotors and track bar if you want the 99.5 bearings are half the price of the e99
99 7.3, 6" stacks, 37x13.5 km2s, ev boost, trans temp and egt gauges, 6637 intake, tw tunes, cnc fab 4 line fuel feed kit, hpx, boost fooler, john woods valve body, triple disc billet tq conv, swamps idm, MB hoop, comp cams 910-16 valve springs .030 shims, smith brothers pushrods and PIS 250/200's, PMF stage 2 gusseted trac bars, 4" icon lift
mxracer511 is offline
post #7 of 46 Old 09-03-2013, 04:40 PM
Macon's Avatar
Are the ports on the intercooler a different size?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #8 of 46 Old 09-03-2013, 05:17 PM
Quoted: 816 Post(s)
Nope
post #9 of 46 Old 09-03-2013, 06:19 PM
schlutzer's Avatar
Quoted: 18 Post(s)
The intercooler pipes are the same too, somebody said somewhere that they wont match up but I have a pipe from an 02 on one side of mine, and a 00 one on the other.
post #10 of 46 Old 09-03-2013, 06:24 PM
Macon's Avatar
Originally Posted by hucorey View Post
Nope
Cool. I know IC boots have different sizes, but I wasn't sure if it was just intake side.
2002 F250 CCSB 4x4
Macon is offline
