Going to look at 2002 F350 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-02-2013, 03:47 PM Thread Starter
Hanlon99's Avatar
Quoted: 13 Post(s)
Hey folks, I am going to have a look at a 2002 f350, the truck was owned by a independent roofer who towed a dump trailer. The truck looks to be in mint condition from the pictures, no rust. I will be using it for towing dump trailers and large enclosed trailers.
The truck has 345k (Kilometres) I know thats getting somewhat high but I figure if it's in good condition I will have a look at it.
I have a good list of stuff to look at such as oil leaks in different places, smoke coming out of oil fill tank, steering issues, brakes.
I'm curious if there is any simple things to look over that will tell me to walk away from the truck or not, I am obviously worried most about a worn out motor. Obviously I can't do a compression check in the guys driveway. I plan on bringing a friend who is a diesel mechanic, powerstroke mainly.
Any info would be great, thanks guys.
Hanlon99 is offline
post #2 of 5 Old 09-02-2013, 04:15 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 5 Post(s)
check for blue smoke at start up and when idling especially when its warm. take the oil fill cap off and turn it over and set it back on the oil fill pipe at an idle. it should only vibrate around from the engine vibrations ,if it it bounces from pressure coming out the fill pipe you have blowby from worn rings and low compression
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 5 Old 09-02-2013, 04:20 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 5 Post(s)
my truck has 289k miles and runs strong , no blowby and will only use 1 qt of oil when it hits the 5000 mile oil change. maintenance = longevity just remember , the drive train also has the high mileage so check for leaking differential wheel seals , any rumbling or grinding can be bad wheel and or axle bearings
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
post #4 of 5 Old 09-02-2013, 04:31 PM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
NoRalPh is offline
post #5 of 5 Old 09-02-2013, 06:26 PM Thread Starter
Hanlon99's Avatar
Quoted: 13 Post(s)
Great, thanks for the oil cap tip.
Originally Posted by NoRalPh View Post
Exactly what I was looking for, thanks.
Hanlon99 is offline
