Another a/c problem thread - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-01-2013, 04:48 PM Thread Starter
99 f-250 sd cc. Ok, so I can get the compressor to power up off the battery. Can not find any blown fuses and the relay works. The hvac fan comes on in all modes at all speeds. I haven't checked out the coolant level but I did check, I believe the low side switch/bypass. When I pilled the wiring to the switch, I didn't get 12v. I am assuming the switch is the one right near the compressor. BTW, the compressor spins freely and, again, I can turn it on. So what should I do next. FWIW, I've been checking around for ideas and they got me this far. Oh, and I'm bs with electrics. I do have a battery charger, jumpers, digital volt meter w/ohms, etc.
markwemple is offline
post #2 of 6 Old 09-02-2013, 09:05 AM Thread Starter
FWIW, the heat and blower functions work fine. Also, I have checked the air gap as I didn't think that this would stop it from working all the time. And, again, I think I'm not getting power to the low side switch. Just now 100% positive what I checked was the low side switch.
post #3 of 6 Old 09-02-2013, 11:34 AM
goats's Avatar
Quoted: 2 Post(s)
Sounds like you could be low on freon
goats is offline
post #4 of 6 Old 09-02-2013, 12:12 PM
Sediment's Avatar
R134a kits are available at auto parts store nationwide. Get the proper oil with the home recharge kit also. Quick fix and no hazmat license required.
Sediment is offline
post #5 of 6 Old 09-02-2013, 04:31 PM
Quoted: 17 Post(s)
Check your pressure first before you just start throwing refrigerant in. If you are low you need to find the source of the leak then repair it. Then evacuate & recharge if you had to remove refrigerant (legally you have to recover it)or if it was flat.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #6 of 6 Old 09-02-2013, 05:15 PM
Quoted: 17 Post(s)
Also you have a low pressure switch,refrigerant containment switch, then from the PCM is the head pressure switch & clutch relay. So there's quite a few other electrical devices keeping it out.
TBJK is offline
