Door Ajar and interior lights stay on - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-31-2013, 09:12 PM Thread Starter
AUSPowerstroke's Avatar
Hey guys, having a bit of a problem with my interior lights and the door adjar light on the dash, it started happening a few weekes ago, id jump in start it up and drive off but the lights would stay on, after a short while they would go off, started to get worse quickly, after a while the interior lights would turn off but the light on the dash would stay on, this is how it currently is all the time, but when I park and lock it all interior lights stay on all the time, I had a quick look for a switch or a adjustment but couldn't find anything, is suspect it could be the RHR door but not 100% sure, I ended up pulling the fuse so the lights would be off while its parked, does anybody know of this issue or how I can fix it
thanks
2003 F250 7.3l (RHD), auto, 4"lift, 315/75R16's, arb steel winch bar, 12,000lb winch, 30" LEDlightbar and 2x lightforce 240 spotlights, Snorkel, edge cts attitude tuner, 5"stright through exhaust, Custom made rock sliders, Front and Rear ARB air lockers, still more on the list to be done
AUSPowerstroke is offline
post #2 of 10 Old 08-31-2013, 11:58 PM
schlutzer's Avatar
Quoted: 18 Post(s)
It's a free fix, or almost.
Go pick you're favourite brake cleaner and penetrating oil.
Spray all the door latches with te cleaner then the lube.
Open and shut the doors a few times.
Spray some more lube.
Drink a beer because everything works now.
A more permanent fix is to take the latch right out and clean it, thn load it with a graphite lube as I have done because winters here get real cold.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 10 Old 09-01-2013, 12:40 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Agreed ^, maintenance goes a long way with any vehicle and Super Dutys are no different!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 10 Old 09-01-2013, 02:51 AM Thread Starter
Well that's a easier fix then I thought it would be, cheers guys, I'll get it sorted
post #5 of 10 Old 09-01-2013, 05:02 AM
Colin7.3's Avatar
Mine was so far gone. I tried the fix method. Bit ended up having to buy new door jamb switches. Not bad to replace but you have to unbolt the latch to get the things to turn enough
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #6 of 10 Old 09-02-2013, 09:47 PM
Quoted: 8 Post(s)
Yep, if left unresolved for a while they will need replaced. I lost a $50 bet when I told a friend I could fix it with a couple shots of wd-40. ever single other time (my two precious super duty plus 7 different one at work) it just need a little cleaning and lubrication!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 10 Old 09-03-2013, 06:21 AM
Quoted: 2 Post(s)
I just did mine. The WD-40 trick did not work from outside, so I pulled the interior door panels, reached in and removed the "door ajar" switches. They're a real pain in the butt to take out, and it feels like you're going to break them right before they come loose. The little plunger that senses whether the door is open or closed was gunked up and stuck in the depressed position. Some "up close and personal" WD-40, followed by vigorous "exercise" got them working perfectly again. It was totally worth it to do the fix, but it's definitely a job that requires an entire six-pack nearby.
Stefonius is offline
post #8 of 10 Old 09-03-2013, 08:46 AM
Quoted: 8 Post(s)
Light truck porn... Nice!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 10 Old 09-03-2013, 06:23 PM
Galaxie's Avatar
Do you have little hands? If so its an easy change. haha
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #10 of 10 Old 09-03-2013, 08:39 PM Thread Starter
Thanks for the help guys, have all locks a spray last night and seems to have fixed it
I was so happy it works now I had 6 :p
