driving like !t..... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-31-2013, 10:26 AM Thread Starter
Angry driving like $h!t.....
bought this 2003 f350 few weeks ago. has 12in lift/leaf springs and 38s. drove home first night(1.5hr drive) no problem couldn't ask for better. then all a sudden on that same trip a week later front end started to drift left and right. bump steer? real bad on highway(ruts from semis) installed brand new remaned steering gear box.. same prob. installed new rancho dual steering stabilizer set up.. still doing it.. now while driving front end almost acts like the axel is floating back and forth.. EVERYTHING under front end is tight no end no bushings bad!! what do you guy think???
jthaxton is offline
post #2 of 3 Old 08-31-2013, 10:49 AM
rdaffin's Avatar
Is tire pressure good? With tires that size air pressure is important for proper handling. Also check the drag link bushings. It is what holds the axle centered.
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #3 of 3 Old 08-31-2013, 03:20 PM Thread Starter
yep tire pressure is 65psi
jthaxton is offline
Tags
7.3 diesel
