Oil rail plugs - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-30-2013, 08:33 PM Thread Starter
kodeman's Avatar
Oil rail plugs
Hello all, I noticed about 6 months ago that one of my oil rail plugs on the back of the head (against firewall) on the driver side was seeping a little oil. I have a 99 f350 btw.
I had searched and searched here on .org about changing the plugs while the motor is in the truck and everyone says the motor has to come out. so I have been putting it off cause it wasn't leaking to bad
Well a few days ago it started dripping on the ground and I noticed it during an oil change . Stopped by the local ford dealer and bought two new plugs and O-rings. $20 for both , bought two just in case
I used a regular 1/2" drive ratchet with about a 10" handle . I bent the last 3" of the handle about 20 degrees to clear the firewall . It worked good, pulled the old plug out and the oring had a couple missing chunks. Cleaned the thread of oil with brake cleaner on a rag and put red thread locker on the new plugs threads and coated the new oring with clean oil and tightened it up. I only did the driver side , took about 20 mins . For the passenger side it looks like I will have to remove the 4" exhaust downpipe.
Hope this helps for someone with a superduty and a leaking high pressure oil plug. They can be changed in the truck. Kodi
7.3 PSD, Swap'd in ZF6 ,South bend clutch ,BD exhaust brake, 4" lift & 35" Toyo AT2 , 6" Exhaust ,PHP Phoenix, .
kodeman is offline
post #2 of 6 Old 08-31-2013, 08:50 AM
That's a whole lot easier than pulling the engine! Thanks for the tip!
2000 F350 4X4 CCSB w/ 7.3 and 4R100
PIS 175/80, Adrenaline HPOP, 4" Exhaust, 6637 Filter, CCV Mod, Leveled Front, 315/75/16 Goodyear Duratracs
Devil Car is offline
post #3 of 6 Old 08-31-2013, 09:16 AM
usteffenhagen's Avatar
Awesome tip. Thanks!
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #4 of 6 Old 09-04-2013, 06:03 PM
blue72's Avatar
Feedback Score: 5 reviews
Thanks for reporting your results. Just curious, how tight was that plug? Was it hard to break loose?
2000 F350 XLT SCLB 4x4
PHP 6 Pos. Chip
DIY 6637 Induction
Walker Muffler
Stewart Warner Gauges
blue72 is offline
post #5 of 6 Old 09-04-2013, 08:50 PM Thread Starter
kodeman's Avatar
It wasn't to hard to break loose. Dieselorings.com install says use threadlocker and torque to 60 ft lbs.
kodeman is offline
post #6 of 6 Old 09-06-2013, 01:04 AM
I had to change the driver side on my old '97 F350, and i ended up drilling a hole through the firewall to get to it. I have a 1/2" drive woble ratchet that would fit down in there but did not have any room to break that plug loose. Even going in through the firewall it was tough to break loose.
2002 F350 CC Auto 2x4 SRW SB
jhobbs26 is offline
