Tell me what I did wrong... - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-30-2013, 06:52 PM Thread Starter
ThomasvillePavers's Avatar
Picked up some bad fuel and had a lot of debris in tank so I had to drop the tank and have it cleaned, decide this was the right time to complete the "hutch" and "harpoon" mods and add a pre pump filter and fuel/water separator.
Mods and cleaning went well and the truck went back together, rolled the key forward to prime the fuel system and listened for the fuel pump to cycle 4 times then fired the truck up with 4 gallons of diesel in the tank. About 2 minutes after the start up the truck began to idle rough and got louder and louder I first thought it was the air working out and then realized it was getting worse so I shut it down just before it stopped running by itself... In this time the fuel pump had failed and stopped flowing altogether, I replaced it and filled the fuel bowl back up and she started right away.
We cleaned up our tools and my friend poured in 16oz of diesel kleen before I could tell him to wait for me to fill up, so I drove about 3 miles to the closest station to fill the tank with diesel and on the way she started blowin white smoke bad and worse at idle, after filling the tank completely I drove 50 miles and it still smokes BAD at idle and much less when the engine is revved!
Did I kill an injector when it ran out of diesel? Was the heavy mix of diesel kleen bad? Will this clear up if it is the diesel kleen?
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #2 of 16 Old 08-31-2013, 01:17 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
It's not the Diesel Kleen. If it's pluming straight white smoke, I'd vote for a bad injector(s).
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 16 Old 08-31-2013, 04:13 AM Thread Starter
It just seems so unusual because there was no sign of anything before the repairs yesterday and even now with the smoke at idle the truck runs smoother, quiter and stronger than before...Just smokes a lot at idle...
I will do a buzz test today I guess.
-Brad
post #4 of 16 Old 08-31-2013, 05:48 AM
Quoted: 763 Post(s)
White smoke. Does it smell sweet or like fuel? Sweet is coolant. Like fuel, its oil. I don't think it had anything to do with your repair, just bad timing. Sounds like an internal or external O-ring went south on an injector.
Buzz test and CCT should show you which stick it is. Or you could pull the valve cover and remove one plug at a time.
Corey@CNCFAB is online now
post #5 of 16 Old 08-31-2013, 07:26 AM Thread Starter
it is a fuel smell and confirmed while testing...
Just did the buzz test and all tested ok, the tool we have states it cannot communicate with the PCM for contribution test even though it has it listed for active testing. While doing these tests we noticed fuel leaking from the exhaust side of the turbo so obviously one of the injectors (or more) is pouring fuel. Any ideas without the contribution test to determine which injector it is? is pulling the valve covers the next step?
-Brad
post #6 of 16 Old 08-31-2013, 07:38 AM
Quoted: 763 Post(s)
Without the CCT then yes, a valve cover then unplug one at a time. Just do one valve cover at a time. You got a 50/50 shot on what side its on. I suppose you could unhook the main plug on one of the harnesses but it will run pretty rough. You won't hurt anything though.
post #7 of 16 Old 08-31-2013, 07:41 AM Thread Starter
Thanks for the quick help!
If I unplug the injectors one at a time I assume it would take some time to stop smoking? because the engine runs very smooth (if there wasnt any smoke I wouldnt know there was an issue) I can't say that I will hear a difference aside from no smoke and no noticable fuel leaking from turbo mount?
-Brad
post #8 of 16 Old 08-31-2013, 07:47 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
I once added diesel kleen to an almost empty tank when I was about to fill up
the realized the schitty AM/PM greedy fuel station had one point of unmanned pay for 8 pumps and it was broken
I drove around looking for diesel white knuckled for 10 minutes and found some no issues
later I asked the forums about the issues I may have caused and all agreed that it wouldn't do anything to run on the diesel kleen mix
good luck and keep us posted
oh you have any friends with an A/E diagnostics tool ? they can drop injectors on demand and with the later versions do a contribution test
We Miss you Ronnie
ZMANN is offline
post #9 of 16 Old 08-31-2013, 07:49 AM
Quoted: 763 Post(s)
It won't take as long as you think.
post #10 of 16 Old 08-31-2013, 08:44 AM Thread Starter
The smoking has slowed down quite a bit and the fuel leak from turbo has slowed down to barely wet now after some more injector tests and the buzz test. I tried the UVCH dissconnect and aside from the engine performance drop as expected the smoke and fuel leak seemed to stay the same even after 5 minutes each side unplugged. I am making some more phone calls to some friends to get another scanner here that can complete the CCT.
This scanner keeps showing the CCT as an option for this truck and will begin the test but then faults out to no communication with PCM. All other tests complete OK with this tool.
-Brad
