Injector "ping".. possibilities? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-30-2013, 05:25 PM Thread Starter
codyryan07's Avatar
So, little back story. Ran out of diesel, filled up and wouldn't start. Turns out pump lost its prime, wouldn't pump fuel just air. Got the truck going again, and now every time on start up i get a "ping" and a slow start (may not be the best description) i just know it doesn't sound right. What are some things to check for? Fuel pressure is good. Engine has a slight lope after driving a bit, but nothing else has changed. Did I mess up an injector?
Can't really afford to take it to a dealer because local they charge $115 just to hook it up and pull codes. Diagnostic testing just sky rockets from there and the local diesel 'mechanic' would tell me to throw a bully dog tuner on it and be done any help is highly appreciated. Just need a starting point. Btw, i have the torque app and a BT adapter on the way so i can get a few readouts soon.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #2 of 12 Old 08-31-2013, 07:47 PM Thread Starter
codyryan07's Avatar
Anybody? Looking for somewhere to start
Cody Ryan
4" RC lift
rebuild coming soon
post #3 of 12 Old 09-01-2013, 04:55 AM
Quoted: 172 Post(s)
Feedback Score: 3 reviews
Coupla things that would occur to me...
Next time you start, and would expect things to "sound" different, try cycling the key to ON for 15secs Three times and then start. This would fully purge & pressurize the system and if it behaved normally you'd know which "side" of the system was causing it.
Next, because both the Fuel and HiPres Oil systems are dead-headed (in the heads), without "crossover" connections (like the FrX HpX) it can take some time to purge air once introduced. Have you put 100mi on the truck since this happened yet? Might cure itself
NoRalPh is offline
post #4 of 12 Old 09-01-2013, 05:05 AM Thread Starter
codyryan07's Avatar
I have a full regulated return, and its been about 75-80 miles. It only does it during start up though. Ive cycled the keys and tried listening and nothing sounds out of place then i start and while turning over it makes a horrible.. ping, clank screach.. idk how to describe it. After its running, it drives fine but after some short driving it starts a lope. Checked pressure and its holding steady at 67psi.
Cody Ryan
4" RC lift
rebuild coming soon
post #5 of 12 Old 09-01-2013, 10:37 AM
Quoted: 172 Post(s)
I wonder if your App will do cylinder contribution?
That might be a start...
NoRalPh is offline
post #6 of 12 Old 09-01-2013, 12:52 PM
ThomasvillePavers's Avatar
No, unfortunatly the Torque pro app does not have cylinder contribution, buzz test or DEL-PER testing yet.
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #7 of 12 Old 09-01-2013, 02:01 PM Thread Starter
codyryan07's Avatar
It will read cranking oil pressure, correct? It's a very slow start sometimes. So it may be HPOP related. I do have 300k+ on the truck.
Cody Ryan
4" RC lift
rebuild coming soon
post #8 of 12 Old 09-01-2013, 02:13 PM
Yes it will read, however there can be a slight .5 - 1.0 second delay on the BT setup, it is very close to realtime Data but I haven't used it to diagnose a start issue before.
-Brad
post #9 of 12 Old 09-03-2013, 09:42 AM Thread Starter
codyryan07's Avatar
So it's getting worse.. I'm not thinking it's injector related anymore. Cranks have gotten slower and the noise has gotten louder. I tried getting a quick video earlier but idk how well it will work.
Cody Ryan
4" RC lift
rebuild coming soon
post #10 of 12 Old 09-04-2013, 01:27 PM Thread Starter
codyryan07's Avatar
Fixed!
Turns out a starter bolt had fallen out and starter backed off, and didn't fully engage. Luckily, i picked up this bolt out of the middle of the parking lot at work and after a quick once over on my truck, chucked it in the tool box and didn't think much else. Well today, went to leave work and truck just grinded and screeched then barely caught, trying to turn over then started the noise again. Pulled cover under trans to see if it was flex-plate or starter teeth missing. Bumped the starter when pulling the cover and noticed it was loose, as in close to 1/4" gap between mounting surfaces. Bolted back up, checked the bolt i had picked up, it fit, then noticed the solenoid wire had backed off and barely making contact, so that explains the slow start. Sorry for the novel, but man I'm glad it was a simple fix!
Cody Ryan
4" RC lift
rebuild coming soon
