  #11 (permalink)
Old 05-25-2008, 02:17 PM
sirnunya sirnunya is offline
are you using a wiring harness adapter or doing it by hand? the harness would bypass the factory amp if there was one.
  #12 (permalink)
Old 05-26-2008, 08:06 AM
Speedyboy487 Speedyboy487 is offline
Berm Buster
There is no factory amp though. Im sure if you try a different cd player it would work.
  #13 (permalink)
Old 05-26-2008, 11:04 AM
either way he should have the harness. its hard for me to believe that it just worked in an f350, and he moves it over to a similar truck and it doesn't. sounds like a wiring problem to me
  #14 (permalink)
Old 05-26-2008, 11:41 AM
2000blackbeauty 2000blackbeauty is offline
i would say go into your controls and set the sound to come out of one corner at a time, see if you have any sound then. and if that dont work try looking at the fuse, see if it is blown, if it is not blown i would say that some where you have a fault in your wire, if this does not work, send me a pm. im pretty handy with wireing in aftermarket stereo things
  #15 (permalink)
Old 05-26-2008, 11:46 AM
cja7928 cja7928 is offline
This may sound stupid but one way to know for sure if the deck is putting out is touch two of the speaker wires coming from the deck to your tongue and slowly turn up the volume. You will fell a tingling if its working. also check the ground on your deck ive had a deck with a bad ground appear to come on but did some wierd stuff till I got the ground fixed.
  #16 (permalink)
Old 05-26-2008, 11:50 AM
i assume you got the correct wires going to the speakers but just in case here is the wiring. hope you get it working
  #17 (permalink)
Old 05-26-2008, 03:54 PM
powerstroke23 powerstroke23 is offline
i am going to try putting in a different radio i just really need this one because it has the plug for my sirus radio. i have been alittle busy with the new baby i will let you guys know what happens thanks for all your help.
  #18 (permalink)
Old 05-26-2008, 10:19 PM
with the second unit everything works fine anyone know what could be wrong with bad radio?
  #19 (permalink)
Old 05-27-2008, 12:26 PM
internal amp is bad?
  #20 (permalink)
Old 05-27-2008, 12:47 PM
strokerguy strokerguy is offline
it might have shorted or blew the radio, but it worked in the other truck right
