Snapped fuel bowl regulator fitting when tightening fuel return line nut - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-27-2013, 03:08 PM Thread Starter
SixOhPowerstroke's Avatar
Quoted: 2 Post(s)
Angry Snapped fuel bowl regulator fitting when tightening fuel return line nut
Well i was putting in a new rubber sleeve on the return line that goes to the regulator, wrapped the threads on the regulator a couple times with teflon tape, started to tighten the nut and it snapped the fitting on the regulator clean off. How can i fix this now. I know i need a new regulator but the nut is stuck on the fuel line with the threaded peice from the regulator inside it.
2005 F-350 Reg cab Fx4 - Deleted, updated, bullet proofed. TSD tuned. 18x10 moto metal 962's, 35x12.50 federal mt's, 2'' level, mbrp exhaust, ect, ect. Western Ultra Mount 8' Plow. Money maker/work horse.
SixOhPowerstroke is offline
post #2 of 7 Old 08-27-2013, 11:59 PM
CSIPSD's Avatar
Have to get ahold of it with an easyout or vice grips...
Good time as any to upgrade a bit...
Riffraff Diesel: Fuel Rail Crossover™
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 7 Old 08-28-2013, 01:11 AM
Quoted: 862 Post(s)
Feedback Score: 3 reviews
Next time, don't put any Teflon tape on those threads, it does nothing. The threads are a straight thread (which are not made for sealing). Very similar to ORB hydraulic fittings but obviously the fuel lines are lower pressure.
The only type of thread you use tape or pipe sealant is a tapered thread.
Corey@CNCFAB is online now
post #4 of 7 Old 08-28-2013, 08:45 AM
timmyboy76's Avatar
if you dont want the FRx, some supplier sells just the new billet aluminum FPR with different rate springs....FOUND IT
Replacement Fuel Pressure Relief housing - Billet Aluminum w/pressure shim springs
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 7 Old 08-28-2013, 07:00 PM Thread Starter
Quoted: 2 Post(s)
Well the truck is sitting out of commission but yes I ordered the riff raff FRX and will be having that installed. I will figure something out with the return line in the mean time. But what color frx spring should i use, truck is bone stock except a 4 inch turbo back.
post #6 of 7 Old 08-28-2013, 07:47 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
You will need to monitor the fuel pressure. You can use an in cab gauge, or you can use a liquid filled gauge there at the bowl. But use the black spring. Iirc it gives you about 65-70 psi fuel pressure, and our trucks work great at that pressure
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #7 of 7 Old 09-04-2013, 05:53 PM Thread Starter
Quoted: 2 Post(s)
Well being the hack I am i used Jb weld to hold it for a week, today I heat it up and removed it, installed the frx with the gold spring, ended up buying new fuel lines (supply & return). Now it runs better than ever, smoother, quiet, less clanky diesel sound, and most importantly no more leaks.
