AC Compressor won't engage - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-27-2013, 01:31 PM Thread Starter
Howdy! My AC Compressor won't engage. Is there a fuse or relay that I'm not finding? I've looked through my manual several times...
Heartland Guy is offline
post #2 of 4 Old 08-27-2013, 02:36 PM
JSchuricht's Avatar
Could be any number of things. You need to hook up a scanner so you can see if it's actually being commanded on. It could be anything from a bad clutch, bad wire, pressure switch, fuse, control panel, etc.
JSchuricht is offline
post #3 of 4 Old 08-27-2013, 02:41 PM
c69ss396's Avatar
jump the low pressure sensor if it comes on then your either low on freon or a bad sensor. I'd put my money your low on freon..
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 4 Old 08-27-2013, 04:01 PM Thread Starter
Thanks! I appreciate the tip.
