2nd power steering pump in two years wtf?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-26-2013, 09:48 AM Thread Starter
silveradobeast's Avatar
ive changed my ps pump 2 times in two years i got it from advance and it seems like the 2nd one is going out again the steering wheel is really hard when the truck is sitting still but normal under driving conditions any idea why this is happening? need some input on this ima doing something wrong?
thanks!
k&n/6637 filter,PHP TUNED,4'' turbo back,foil delete and 6.0 tranny cooler.. AKA Rebecca
silveradobeast is offline
post #2 of 5 Old 08-26-2013, 02:05 PM
codyryan07's Avatar
Did you use power steering fluid or ATF? Lift and oversized tires? Sorry, on my phone so i can't see sigs. The tough turning when stopped is a common thing on these trucks due to the axle setup. My truck does it in spells and is worse now that im running a 12" wide wheel. Gotten to where i just man handle it for now. About the only solution I've found without doing axle swap and all is a hydro assist.
Btw, parts store replacements are notorious for dying on our trucks.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #3 of 5 Old 08-26-2013, 02:11 PM Thread Starter
no lift. over size tires 295's and i used power steering fluid
post #4 of 5 Old 08-26-2013, 02:31 PM
codyryan07's Avatar
The owners manual calls for ATF. Check it for the type and do a flush. I bet that will help your problem.
Cody Ryan
4" RC lift
rebuild coming soon
post #5 of 5 Old 08-26-2013, 04:34 PM
Quoted: 759 Post(s)
Yep. PS fluid will tear up the pump. ATF is required. Doh. It happens.
Corey@CNCFAB is offline
