106k mile 7.3 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-25-2013, 07:28 PM Thread Starter
106k mile 7.3
so i bought my first 7.3 the other day , couple things i found odd ....1 , there was a corrosion type green stuff on top of motor and kinda running down front of motor (not a actual liquid but a corrosion yellow greenish stain) it looked like cooked up coolant ....next i noticed a good amout of oil residue on very top of motor around all the wire harness and plugs in front of the turbo .....anyone seen this or know what it could be ? the engine has almost no blowby and no active leaks that i have noticed so far , runs smooth and sounds good to me , i was just wondering if i should be concerned .....
SUPRA180 is offline
post #2 of 6 Old 08-25-2013, 07:33 PM
camsmell's Avatar
might be t-stat housing leaking a little
99.5 F250 full force stage II, riff raff frx hpx, T 500, 6637 mbrp stainless 4", DP Tuner, Isspro boost pyro trans, 4" lift john wood vb, 38r, coolant filter, ccv mod, cooling mist stage I, non ebpv pedestal
camsmell is offline
post #3 of 6 Old 08-25-2013, 07:50 PM
Quoted: 722 Post(s)
Wash it out real good then recheck it out a week or so later.
Oil residue around driver valve cover could be the CCV O-rings are bad.
Plug in front of turbo is probably the turbo to pedestal O-ring leaching to the plug. I've never heard or seen the plug leak.
Corey@CNCFAB is online now
post #4 of 6 Old 08-26-2013, 09:26 AM Thread Starter
whats ccv ? im tryin to get used to all these new terms
SUPRA180 is offline
post #5 of 6 Old 08-26-2013, 09:33 AM
timmyboy76's Avatar
CCV = crankcase vent
EBPV = exhaust backpressure valve
EBP = exhuast backpressure (sensor)
CPS = cam position sensor
ICP = injection control pressure (sensor)
IPR = injection pressure regulator
IC = inter cooler
IIRC = if i recall correctly
WP = waterpump
theres more, but its early for me...hahaha
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 6 Old 08-27-2013, 08:25 PM Thread Starter
thanks guys
SUPRA180 is offline
