just wanna pick some brains - Ford Powerstroke Diesel Forum
post #1 of 33 Old 08-24-2013, 08:43 PM Thread Starter
jjaggard's Avatar
Quoted: 2 Post(s)
So my check engine light would come on when accelerating. More so with a load but still all the time when going up hill. Once check engine came on all power lost, shut off truck restart and all back to normal.
So far I've checked fuel pressure, was 55psi at idle and 42-50 at WOT. Ran AE, at idle everything was fine.At WOT going up hill; Duty cycle-88.87%(high?), ICP-1900PSI(low?). Codes P1209 - ICP peak delta test fault, P1668 - PCM/IDM Communication error, P1211 - ICP higher/lower than desired
Changed oil, filter, fuel filter. All not that old but cheaper than anything else. Re-ran tests AE said same as above except codes were only P1211 and MIL went out on its own after a few seconds. But ICP and Duty cycle still the same.
So what do you all think? Need to clean and re-o-ring IPR? Replace ICP? (No leaks in ICP harness) Or replace HPOP
Or am I not even looking in the right place?
2003 F-350
Ford AIS
That's it so far
jjaggard is offline
post #2 of 33 Old 08-25-2013, 02:24 AM
over boost causing it to defuel?
2002 F350 CC Auto 2x4 SRW SB
jhobbs26 is offline
post #3 of 33 Old 08-25-2013, 11:18 AM
Joel's Avatar
Quoted: 10 Post(s)
My ICP is lower and my IPR is higher on the DP tuner. So I don't think that's your problem.
I'm not sure what your fuel pressure should be, but mine never goes below 60psi at full throttle. And closer to 65 at idle. My fuel system is all stock.
If you can rebuild your IPR I would try that, it's basically free. My IPR was bad before and I replaced it, made a big difference.
Good luck
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 33 Old 08-25-2013, 12:02 PM Thread Starter
jjaggard's Avatar
Quoted: 2 Post(s)
I am planning on rebuilding IPR today. But can't find anybody open that sells it. They want $700 up here for a reman. IPR. that's a new pump!
2003 F-350
Ford AIS
That's it so far
jjaggard is offline
post #5 of 33 Old 08-25-2013, 12:33 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
reman ipr from dieselsite is like 80 bucks, thats where i got mine and it works great.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 33 Old 08-25-2013, 08:06 PM Thread Starter
jjaggard's Avatar
Quoted: 2 Post(s)
So cleaned ipr and no difference
Any other thoughts? Maybe just a new hpop has almost 300,000 miles. Or will a faulty icp cause high duty cycle?
2003 F-350
Ford AIS
That's it so far
jjaggard is offline
post #7 of 33 Old 08-25-2013, 08:26 PM
mcyrana's Avatar
dont buy anything, I work for international as a Tech and deal with this stuff all the time.
But when you throw over 22-24 pounds of boost your check engine light will come on but shut off after some driving to make sure it doesnt overboost again.
also if you shut your truck off and turn it back on the light will be off.
So Since when your light comes on when under hard acceleration and more when under a load thats when your turbo is going to make the most pressure
I throw that code all the time because I get up to 35 pounds of boost when im towing or really mash my pedal
The ICP higher/lower than desired comes on because the computer sees the high boost and the the ICP an IPR pressures are not proportional with what the boost should normally be. Hopefully that made sense
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #8 of 33 Old 08-25-2013, 11:36 PM
CSIPSD's Avatar
If your seeing anything above 65% duty cycle you have an ICP issue... 80% is more or less the IPR being closed and not bypassing any pressure.
Good luck
If your tuning is asking for lower numbers then that then take it out and throw it in the trash...
ICP on a WOT run should be 2500-2800psi on stock tunes, 2700-3000psi on a hot tune...
If your Duty cycle is EVER above 65%, then you have ICP issues...
The hard part is finding out what those issues are.
Could be injectors, injector O rings, ICP sensor, IPR, HPO, HPO rail leaks... Takes a bit of work to chase it down...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 33 Old 08-25-2013, 11:39 PM
CSIPSD's Avatar
Ugh...
You work at IH and you spew this crap?
Good lord.
Joe
CSIPSD is offline
post #10 of 33 Old 08-26-2013, 04:18 PM
mcyrana's Avatar
So now that i actually reread that holy crap maybe I should proof read before I post late at night
Just made myself look like a horses rear end
mcyrana is offline
