Truck cranks and cranks then starts - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-24-2013, 04:03 PM Thread Starter
camsmell's Avatar
Hey all I have recently been letting my truck sit and have only put about 30 miles on in the last month and I am having a hard start issue. The truck cranks for 10 or15 seconds then starts and runs fine most of the time sometimes it romps then smooths out but once it romped a couple times then died. I am not sure where to begin I do not have access to a scanner or anything like that right now but am going crazy because my truck is not perfect right now any help would be greatly appreciated thanks
99.5 F250 full force stage II, riff raff frx hpx, T 500, 6637 mbrp stainless 4", DP Tuner, Isspro boost pyro trans, 4" lift john wood vb, 38r, coolant filter, ccv mod, cooling mist stage I, non ebpv pedestal
camsmell is offline
post #2 of 12 Old 08-24-2013, 05:20 PM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
how old are your batteries? sounds like they are getting weak
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 12 Old 08-24-2013, 05:30 PM Thread Starter
camsmell's Avatar
The batteries are 4 years old and I did hook up the battery charger for about 30 min and left it hooked up and started with the same result lots of cranking before starting
camsmell is offline
post #4 of 12 Old 08-24-2013, 06:02 PM
Batteries and Starter are the first things to check. Sounds to me like you need batteries though if the starter seems to crank fine.
Might be time for some new glow plugs too. Or a relay. Milage? ever put glow plugs or a relay in?
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #5 of 12 Old 08-24-2013, 06:52 PM Thread Starter
camsmell's Avatar
glow plugs and relay were replaced before I bought the truck I have recipts for them not to many miles also it does it at any temp if I drive it down the highway for about 2 hours it starts fine until it sits again
camsmell is offline
post #6 of 12 Old 08-24-2013, 07:11 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
Glow plug relay fixed my neighbor's when it did that. Get a spare while you're at it.
AU7POINT3 is offline
post #7 of 12 Old 08-24-2013, 07:35 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
if it is the gpr get the stancor/white rodgers relay.
check your oil level. when my oil was low it did this.
might be time for a oil change too?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #8 of 12 Old 08-24-2013, 08:11 PM Thread Starter
camsmell's Avatar
it has the stancor relay and I will change my oil tomorrow I already have it there is only 3k on the rotela 5w40 synthetic I have hooked my volt meter up and when key is on I can watch my voltage drop to 11.xx and cranking it is 10.xx which seems low to me but it was the same with the battery charger hooked up
camsmell is offline
post #9 of 12 Old 08-24-2013, 08:56 PM
Quoted: 258 Post(s)
well if your oil is only 3k old i wouldnt change, just verify it is at the correct level.
pull the icp and see if theirs oil coming through.
make sure you are getting fuel to the fuel bowl as well.
post #10 of 12 Old 08-25-2013, 07:52 AM Thread Starter
camsmell's Avatar
When I pull the icp am I taking it out of the head or just pulling the connector
camsmell is offline
