Which leveling kit to choose - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-23-2013, 06:46 PM Thread Starter
Cummins_Killer's Avatar
Title pretty much says it all, my truck has a 1/99 build date so im guessing its an e99. Thanks
Cummins_Killer is offline
post #2 of 9 Old 08-25-2013, 06:21 PM
Procomp makes a good leveling kit that comes with everything you need to level your truck
cory5517 is offline
post #3 of 9 Old 08-25-2013, 07:08 PM
Quoted: 859 Post(s)
Feedback Score: 3 reviews
You can get x code springs. They are only $300 with new u-bolts.
Corey@CNCFAB is offline
post #4 of 9 Old 08-26-2013, 01:43 AM
goats's Avatar
Quoted: 2 Post(s)
You have a late 99
goats is offline
post #5 of 9 Old 08-26-2013, 04:47 AM Thread Starter
I thought pre 3/99 is early 99 suspension and pre 12/98 is early motor, so mine is a cross breed
post #6 of 9 Old 08-26-2013, 07:38 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Depending on the amount of lift you want the best riding kits will be either hanger kits or a mini spring pack..limited to 2.5"
Hangers for a level kit 2-3"
Mini spring packs can reuse stock length shocks, hangers need longer.
Also X codes but will ride stiffer.
All kits require a adj track bar to recenter your axle.
We have all, PM if we can help.
CT Performance, Inc. is offline
post #7 of 9 Old 08-26-2013, 02:50 PM
Quoted: 859 Post(s)
Pretty much what CT said.
Except for one thing when I did my e99 I bought a 2000 track bar with x code springs and it lined my axle up perfectly centered. I did have to oversize the bolt holes on my mounts though. Its really not that much more though to get an adjustable track bar plus the pita it is to drill out the holes.
Personally, I didn't feel any ride difference going to x codes. I have about 7k miles on them.
post #8 of 9 Old 08-26-2013, 03:45 PM
Quoted: 3 Post(s)
Many times the springs will move over the sleeves so axle is centered but springs are shoved against the mounts. Then again every truck is different and nothing is in concrete.
post #9 of 9 Old 08-26-2013, 03:57 PM
Quoted: 859 Post(s)
Most have no idea how dangerous it can be drilling out 7/8" holes with a 1/2" DeWalt hand drill. It SUCKS and can break you wrists. I'll spend the extra $50-60 bucks to get the adjustable.
Fwiw the 2000 track bar is 5/16-3/8" longer center to center than the e99.
