Anyone running a oil bypass system? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-23-2013, 06:11 PM Thread Starter
simone0414's Avatar
Looking for input on these. Do they work?? How much do they increase the life of your oil??
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #2 of 3 Old 08-23-2013, 08:28 PM
Quoted: 768 Post(s)
They will keep the oil cleaner as to dirt etc. But it won't help with shear or TBN. Huei systems tend to shear the oil much more than traditional diesels.
If you get it for a good price it may be worth a shot and send in some samples for analysis. :thumbup:
Corey@CNCFAB is offline
post #3 of 3 Old 08-31-2013, 08:26 AM
I have an FS2500 system on my 2002 7.3..... had it since the rig was 1 year old.
after I installed it, i ran the oil for 40k miles while changing the filter annually and ran oil analysis. Every time oil analysis came back as no change necessary.
Filters are about 27 bucks....
Now. I usually change oil every 20 k miles. My oil capacity is about 16.5 qts.
Well worth the money IMHO.
I run shell Rotella 15-40 exclusively... May switch to synthetic this time around.
mikeprod92211 is offline
