  #11 (permalink)
Old 06-09-2008, 08:53 AM
4D_M8sit_InTrNtNlSh8ks_IT 4D_M8sit_InTrNtNlSh8ks_IT is online now
Originally Posted by TANK'S 250 View Post
That's the beauty of the SPEED WIZARD...there isn't any "screw driver" adjustments....it's "Digital push button"....and.....you can calibrate it in your driveway,...you don't need to be driving down the road to set it.....unlike the true speed.
Where can I get one of these?
  #12 (permalink)
Old 06-09-2008, 09:07 AM
sirnunya sirnunya is offline
Speed Wizard Speedometer Correction
  #13 (permalink)
Old 06-09-2008, 09:24 AM
drstephennix drstephennix is offline
LSP Director
Send a message via Yahoo to drstephennix
I just took mine into Ford and had them do it for $90. They also adjusted shift points as well as the speedometer
  #14 (permalink)
Old 06-09-2008, 01:26 PM
TANK'S 250 TANK'S 250 is offline
Ford can only do up to a 35" tire....
  #15 (permalink)
Old 06-09-2008, 02:18 PM
LSP Director
Good thing thats all i got!
  #16 (permalink)
Old 06-09-2008, 03:01 PM
tp83 tp83 is offline
i wish i knew of that speed wizard my tru speed it a PITA to make correct.
  #17 (permalink)
Old 10-02-2008, 06:19 PM
Mercury Mercury is offline
Send a message via AIM to Mercury
yeah thats the site for the speed wizard - and beleive it or not shift points are not even controlled by the abs module on most of these trucks, shifting is done via load and rpm. Except the 7.3L engines
but if you tap into the speed signal right after the abs module on the 7.3's then it will do the shift point change.
kenny
