Vaccum leak to much boost? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-22-2013, 05:34 PM Thread Starter
jvanwalsen's Avatar
Just today noticed on my gauges that the vaccum at idle is 1.7 normally it ha s been 5.4. Also when I hit the gas I never really got above 1.0 for boost but today on the gauge I saw 5.1, never saw the boost gauge go this high and fuel mileage seems to be down also.
jvanwalsen is offline
post #2 of 6 Old 08-22-2013, 06:32 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Either your boost gauge is broken or your truck has serious issues. These trucks make 0 vacuum at idle. I'm not sure what hitting the gas is for you, but at WOT you should see at least 17+lbs of boost if your truck is stock. Merging on the highway, figure 8-10. Cruising at 70, you should be at 4-5.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 6 Old 08-23-2013, 12:16 AM
Diesels make 0 vacuum period. They are open to atmosphere and do not have a throttle plate. No throttle plate = no pressure differential = no vacuum.
hydroman is offline
post #4 of 6 Old 08-23-2013, 01:29 AM Thread Starter
jvanwalsen's Avatar
So is there a vaccum pump? I am using the torque app for android. Maybe it is set up wrong. Just seeing different numbers with less fuel mileage. What should be checked. Doesnt the 4x4, and heater run off of vaccum?
post #5 of 6 Old 08-23-2013, 02:49 AM Thread Starter
jvanwalsen's Avatar
Man I am an idiot, when I did the gooch flush procedure I turned the chip to high idle when I was done turned it the wrong way and it was on stock.
post #6 of 6 Old 08-23-2013, 03:01 AM
JSchuricht's Avatar
There is a small electric vacuum pump on the passenger side fender. It's only used for the vent controls and automatic 4x4 hubs.
JSchuricht is offline
