Leveling kit question+x code springs?? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 08-22-2013, 05:30 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
I'm trying to decide between a 4" lift with 35's or a simple leveling kit with x code springs and 285's. I've changed my mind so many times you wouldn't believe it. I'm really leaning towards the leveling kit, x codes and 285's seeing as how I really use my truck. I have a legend series ranch hand bumper (aka really f@#$ing heavy bumper) on the front end of my truck and it sits exactly 3.5" lower in the front than in the rear. Im expecting the x codes to lift it some, but not that much. My question, would the x codes coupled with a 2" mini spring pack level out the front? Thanks for the help.
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
