  #11 (permalink)
Old 05-19-2008, 06:43 AM
caryt caryt is offline
You should do under 10 sec with a chip easy, without a 4x4 launch.
The AFE 1 doesn't flow very good so upgrade that to a #2 or better yet a Donaldson filter.
Check your turbo wheel...every other fin should be shorter and the edges un damanged if not get a WW
Tony's chip will wake up that engine and should give you 2mpg.
I'd get some gauges before any other mod.
Cary
  #12 (permalink)
Old 05-19-2008, 02:42 PM
Southpaw Southpaw is offline
1/20/2013
Every other vane is shorter on the ww, they are all the same size on the 99.5-03 stock wheel.
  #13 (permalink)
Old 05-19-2008, 08:36 PM
FordCowboy FordCowboy is offline
yeah mines an early 99 so they alternate. Didn't get a chance to look at the PCM today but will tomorrow
  #14 (permalink)
Old 05-20-2008, 04:00 AM
1/20/2013
Did you get a 0-60 run?
  #15 (permalink)
Old 05-20-2008, 11:28 AM
Just did a couple 0-60 runs and ranged from 11.1 (pretty flat) to 11.4 (a little up hill)
did the best I could looking at the PCM and didn't see anything.
  #16 (permalink)
Old 05-20-2008, 03:14 PM
1/20/2013
HMMMM.....
I would get the chip, i think you will notice a huge difference based on what you've got. There may have been something wrong with your buddies chip to not notice a difference between yours and his. If I remember tonight, I'll hook up my evolution to record a couple of 0-60 times with my DP tuner stock and 140 for ya.
That should give you a little better idea...
  #17 (permalink)
Old 05-20-2008, 08:38 PM
Cool thanks southpaw
  #18 (permalink)
Old 05-20-2008, 08:48 PM
smitty16s smitty16s is offline
Location: Little Rock Air Force Base,Arkansas and North Augusta,South Carolina
def. go with a tony wildman just installed mine yesterday and man its a hell of a diff. and i smokes like a choo-choo
  #19 (permalink)
Old 05-21-2008, 03:53 AM
1/20/2013
Well eith my setup, and my daily driving around weight these days is about 8000lbs.
stock=12.8
80hp=8.7
120hp8.5 broke the wheels loose in 1st and 2nd
140hp=8.5 spun wheels on take off.
all were 2wd
and I know they all don't make sense, but it was only 1 run of each on different peices of road. Just did it to give you some ballpark idea...
hope it helps
  #20 (permalink)
Old 05-21-2008, 04:15 AM
lifewitlooie lifewitlooie is offline
COLLEGE KID
Send a message via AIM to lifewitlooie
all these guys with custom tunes love it. Its almost like they are cheating. From what I read there is no point in wasting your money on the canned tunes like the banks 6 gun and bullydog.
