Steering stabilizers - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-22-2013, 01:40 AM Thread Starter
alexfisk19's Avatar
I got an 01 4x4 f450 with a 4 inch lift and they put dual steering stabilizers under it. I didn't do the work so idk brands. But where can I get a new set from? Is there any reason to do a dual set up? Mine seem to be getting to much play causing the truck to shake bad. Thought it was the ball joints changed them. Had tires rebalanced still nothing
alexfisk19 is offline
post #2 of 5 Old 08-22-2013, 02:45 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
take the steering stabilizers off and see if it still does it.
id say your tie rods are shot or the steering box itself.
you only need 1 steering stabilizer anyways.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 5 Old 08-22-2013, 03:33 AM Thread Starter
alexfisk19's Avatar
Take them off? And drive? I like the look of duals tho lol draws attention lol
post #4 of 5 Old 08-26-2013, 02:11 PM
codyryan07's Avatar
Yep, a lot of trucks didn't even come with em. Mine has a 4" lift and is still OEM. It won't hurt to drive with out it, but your going to feel more bumps and grooves in the road. But check your tie rods and the nut that holds the pitman arm on. If it's loose, you'll need to get a new one and it needs to be torqued to ~400ft. Lbs.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #5 of 5 Old 08-26-2013, 02:23 PM
layson's Avatar
Quoted: 82 Post(s)
I was running 40's with no stabilizer. You got something else going wrong with the front end. Put it up on some blocks and start shaking stuff..LOL. Or even have a buddy steer it while you watch from underneath.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
