6.0 tranny cooler upgrade - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-21-2013, 07:12 PM Thread Starter
corn binder's Avatar
Quoted: 2 Post(s)
what is all involved in upgrading to a 6.0 tranny cooler? or is it easier to just add an aftermarket?
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #2 of 9 Old 08-22-2013, 07:25 AM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 33 Post(s)
For what it's worth - I'm getting the full kit from BulletProof Diesel out of Phoenix.
It's a fairly straight forward swap and there's plenty of threads on here if you use the forum search feature.
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is online now
post #3 of 9 Old 08-22-2013, 07:36 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Heck on my recent road trip the tranny temps were awesome! They never bounced around at all. Unless you just reeley want to upgrade, or you got issues, you might wanna think about leaving things as are. Pretty good set up from the company.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 9 Old 08-22-2013, 08:16 AM Thread Starter
Quoted: 2 Post(s)
I have a 20,000 gvw dual tandem gooseneck I'm going to be towing with, the stock cooler will not be near enough adequate.
post #5 of 9 Old 08-22-2013, 08:29 AM
AzPatMan's Avatar
Quoted: 33 Post(s)
yea, I only tow about 8000lbs right now and it's ok, but I may be going up in weight a bit, and possibly for longer hauls down the road for trips, so I know I'll want to upgrade.
But I think I'm right at the sweet spot for mine
post #6 of 9 Old 08-22-2013, 09:54 AM
Quoted: 13 Post(s)
Here is what I used. It went pretty smooth and is a clean install. Pulled my 7000-8000 lb travel trailer through the hills of MO and never got over 150 degrees according to AE. I did have to raid the pick and pull for a flair fitting to match the radiator for the brake line I fabbed up. It is not pictured. Glad I did the mod. You may have to copy and paste the page listed below if it does not show as a link.
What did you do to your 7.3 Today?
Dave
02 F350 CCLB Lariat 4x4 auto
230,000 on the clock
dieselsite trans filter,
dieselsite coolant filter,
6637 filter
Stancor GPR
6.0 tranny cooler
4" Diamond Eye K4318S-RP exhaust
riffraff regulated return
dual alt.style upper rad. hose
05-07 head light mod
PHP Hydra
Alliant Power 160 single shots
WW2
HPOP system cross over hose from Corey
3 gauge A pillar gauge pod with EGT, trans temp and boost gauges. Autometer ford matched gauges.
glow plug light installed in gauge pod.
welove2drive is offline
post #7 of 9 Old 08-25-2013, 06:20 PM
hansel's Avatar
Quoted: 95 Post(s)
It is one of the best mods you can do, it took my about 2-3 hours some 3/8''-1/2'' fittings and about 5ft of 1/2" transmission line. The hardest and longest part is getting the bumper,grill, grill support piece out of the way. Ounce that is out of the way it's a bolt in replacement, I just came back from towing my Keystone Laredo(8,000+lbs) and the temp never went over 152*
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #8 of 9 Old 08-26-2013, 03:53 AM Thread Starter
Quoted: 2 Post(s)
nice!!! where's the best place to get a 6.0 cooler? does anybody make a complete upgrade kit?
post #9 of 9 Old 08-26-2013, 07:39 AM
AzPatMan's Avatar
Quoted: 33 Post(s)
as I mentioned earlier - BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0 and 6.4
