Hpop reservoir drains out - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-21-2013, 09:24 AM Thread Starter
I've noticed if I let my truck set over night the hpop reservoir drains dry. It fires up in the morning so I know the pickup tube and lpop are working. But when cranking it fires up for about 2 secs then dies. No oil pressure for the first cranking or idle. Reset the key and wait for the light to go out again and she starts and runs fine with normal pressure.
Any thoughts why it drains out?
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #2 of 10 Old 08-21-2013, 09:39 AM
CSIPSD's Avatar
Drain back valve in the HPOP... What do you mean dry?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 10 Old 08-21-2013, 09:47 AM Thread Starter
Dry as in, if you let it set overnight and take the plug out of the top of the reservoir, there's no oil in it.
2000 F550 CC 2WD
Schnot is offline
post #4 of 10 Old 08-21-2013, 07:09 PM
corn binder's Avatar
Quoted: 2 Post(s)
if the hoop res. was dry you'd crank and crank til the resivor filled with oil.
99 f250 4x4 7.3 php tunes,20's
01 4x4 cc srw 7.3 550hp BTS trans
02 excursion LMTD 4x4 7.3
95mustang gt,86 5.0,03 gt
allis chalmers 185-d
corn binder is offline
post #5 of 10 Old 08-21-2013, 07:27 PM Thread Starter
Yep that's what happens. It cranks for a while then starts for a few seconds then dies.
2000 F550 CC 2WD
Schnot is offline
post #6 of 10 Old 08-23-2013, 05:54 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Could be any one of many things. Could be your IPR, leaky HPOP hose or a connection under the valve cover is loose.
I ran into that issue and it ended up being one of the lines in the head was loose and leaking.
Do you see any oil in the valley of the engine?
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #7 of 10 Old 08-23-2013, 06:39 AM Thread Starter
No oil in the valley. I just resealed the whole HPOP and the oil lines with the master kit from Dieselorings.com because I had some slow leaks from the lines. I also replaced the Non-Serviceable Plug because it looked as if that was leaking too.
This drainback problem was happening before I did all of that.
What connection under the valve cover are you talking about. The only connections under there are electrical except for the injector itself.
2000 F550 CC 2WD
Schnot is offline
post #8 of 10 Old 08-23-2013, 06:51 AM
Quoted: 17 Post(s)
Shouldn't have said connections... it was the oil drain plugs on the rail..
Under Valve Cover Oil Rail Drain Plug with Viton O-ring
O-rings dried out.
post #9 of 10 Old 08-24-2013, 02:59 AM Thread Starter
O-rings dried out.
Oh yeah good call. They didn't seem bad when I swapped injectors earlier this summer but I will get some new ones and try it.
2000 F550 CC 2WD
Schnot is offline
post #10 of 10 Old 08-24-2013, 11:58 PM
There is a spring loaded check ball in the HPOP reservoir that I believed is a pressure relief valve that drains excess oil back to the crank case. If that was installed backwards somehow or the spring is weak/clogged with crud it will allow the oil to drain out.
hydroman is offline
