long crank - Ford Powerstroke Diesel Forum
post #1 of 23 Old 08-20-2013, 05:31 PM Thread Starter
long crank
I know there is lots of long crank threads but I none seem to be my exact problem. It takes a long time to crank hot or cold and after just running, but starts up quick after the long crank, not graduadly. I notice the oil pressure light always takes quite a few seconds to turn off. Don't know if this is revalant but icp sensor does have light coat of oil in it. I unplugged it while running and idle roughfens like it shoud, almost dieing once not sure if that is normal?
Few things I have considered starter, hoop leakdown
powersmok is offline
post #2 of 23 Old 08-20-2013, 05:49 PM
Quoted: 786 Post(s)
How many miles on your rig? Could be lpop. Do you have access to obd port scanner to check oil pressure during startup and idle?
Corey@CNCFAB is online now
post #3 of 23 Old 08-20-2013, 05:52 PM Thread Starter
280000 and I do not have access to a scanner
post #4 of 23 Old 08-20-2013, 05:56 PM Thread Starter
Way off topic here but I also have a early 99, how do you like the GTP38r compared to the stock e99 turbo?
post #5 of 23 Old 08-20-2013, 05:58 PM
Quoted: 786 Post(s)
If your on a budget and have an Android based smart phone get the app called Torque Pro $5. And get a Bluetooth adapter $15 amazon. That will at least let you see every sensor your truck has and what its doing. Then you can trouble shoot much better.
Or invest in AutoEnginuity if your not strapped for cash. It does everything.
post #6 of 23 Old 08-20-2013, 06:02 PM Thread Starter
Autoengunity is on the list but torque pro may come first
post #7 of 23 Old 08-20-2013, 06:07 PM
Quoted: 786 Post(s)
I pretty much did all of my mods at the same time except for my stealth HPOP, which isn't on the truck yet.
So performance wise I can't isolate just the turbo to see the difference to have a true good comparison.
But I do like it. The noise isn't any different than my OEM, which I like the whistle anyway. I really like the fast spool up on highway entry ramp hole shots.
post #8 of 23 Old 08-21-2013, 03:59 AM Thread Starter
I noticed that many of the Bluetooth adapters come with their own software, would this be better than the torque pro app
post #9 of 23 Old 08-21-2013, 04:17 AM
Quoted: 786 Post(s)
Honestly I don't know as of yet. I'm still waiting for my Bluetooth adapter to show up. I got it off eBay and when I finally got shipping confirmation, it said its coming straight from China. Ugh. I should've bought from Amazon instead. Would've only been two days.
post #10 of 23 Old 08-21-2013, 06:41 AM
CSIPSD's Avatar
Need to watch ICP and duty cycle while cranking. Could be glow plugs, could be injector issues, could be injector o-rings, could be an ICP sensor, could be IPR issues... without a scanner your pissing in the wind.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
