My poor 7.3.... - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-20-2013, 06:05 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
My poor 7.3....
Had to get rescued by two jeeps today.... I failed her lol...
So story goes... 9:30 last night, I get a text from a loudmouth type I know that has a stock Cherokee. Says it can go anywhere, that type. Well loudmouth took his jeep into an old swamp, there is no bottom to the holes there, but grass grows on top so if you don't walk ahead you get sucked in...
He offers me 50$ to yank him out, so out I go I kind of know the trail and I figure I would get the chance to bug a jeep owner. Well....
He was stuck in a decent spot, he went off the trail and didnt get far I had good ground to pull from. I after lifting the back end of that poor jeep up over and over my 4" strap snapped.
By this time it's late and dark I told him good luck and left... I thought I went back the way I came but I was about a foot and a half over, making all the difference in the world.
Happened at night, I slept in the truck and waited for some other buddies of mine... got a solid 7 hours. I have some night shots but it hadn't moved.
i was stuck good... I'm kneeling infront of the truck in that last picture.
This is what it took to get the front up, 2 jeeps one with a winch the other just being an anchor... 10 000lb winch wrapped 3 times it still barely took it. So instead of getting to bug a jeep owner.... 2 others ones get to bug me
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #2 of 13 Old 08-20-2013, 06:56 PM
rascal's Avatar
Looks like that slick,greasy mud that fills up the tread. I could not even tell those were MTR's! Hey, at least you tried and got to go camping out of the deal!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #3 of 13 Old 08-20-2013, 06:58 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
Hey, it happens to is all. I buried mine last year and had to get an OBS sled puller with 1k lbs in the bed to pull me out. Best part: it happened in my front yard
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #4 of 13 Old 08-20-2013, 07:01 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
oh yeah it was I couldn't believe it the tires instantly turned to slicks and even out on the highway it took 15 minutes to stop throwing chunks
post #5 of 13 Old 08-21-2013, 02:58 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
looks like its time for a locker! but that did look pretty soft.
these trucks are so heavy in the front. makes it difficult to get out of situations like that.
i cant wait for the snow.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #6 of 13 Old 08-21-2013, 11:46 AM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
I just ordered a full spool and Yukon master kit for front. The rear will get the LSD rebuild and stacked tighter
post #7 of 13 Old 08-21-2013, 12:09 PM
rascal's Avatar
A spool is a mechanical locker for the diff, correct?
You should try to find a used Dana60 out of an 03 or 04 and upgrade it. That is my plan eventually.
Good luck.
Rascal
rascal is offline
post #8 of 13 Old 08-21-2013, 12:18 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
A spool permanently connects both axles shafts, by replacing the whole carrier. There isn't a need for a locker in the front. Benefit of having lockout hubs, lock both on a trail, lock one for driving in snow on road that's the nice part of a spool.
And I'm not going to bother with a d60 upgrade until I break this. 9/10 times you snap the knuckle joint and it's the same between the two so I'm not worried. Adding a spool is taking the whole weaker carrier out of the equation
post #9 of 13 Old 08-21-2013, 12:49 PM
rascal's Avatar
I thought the weak point of a D50 was the axle shafts themselves since they are necked down at the carrier.
Rascal
rascal is offline
post #10 of 13 Old 08-21-2013, 12:56 PM
Quoted: 27 Post(s)
I would not put a spool in the front of my truck without upgrading other parts, you will start to blow your U-joints up and strip shafts. Also what is the point of having a locker if you have to leave one hub unlocked???? 1 tire will spin freely no matter what as the other just sits there doin nuthin. And on the trails when you have both locked, you will not be able to turn, especially if you air your tires down.
I would save some extra cash and either get a selectible locker that replaces the whole unit, or a lunchbox locker that replaces your spider gears. These will actually allow you to be able to turn without unlocking one of your hubs.
I do a lot of 4x4ing and the only people i know that have spools in the front are guys that trailer their rigs only and have full hydro steering so they can actually turn their tires, and not one of these people has a 1,000 LB motor sitting on top of their front axle....
For the rear, my buddy is a ford tech and has shimmed the rear limited slip a few times so that they are tighter like you mention and they work more like a locker when you do this so i think this is a good cheap way to get a decent locker in your rear end. .
In the end its your truck and can do whatever you want, just wanted to point out some issues with a front spool.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
