Unknown black material on rear a/c condenser pipes - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-20-2013, 03:49 PM Thread Starter
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
Can anyone tell me what the black spongy tar like substance on the a/c condenser pipes in the rear of my Ex are? It's is put on at the factory but no one at Ford or anywhere else I've been can tell me what it is. I'm relatively sure it keeps the pipes from sweating.
Thanks
403,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #2 of 4 Old 08-20-2013, 06:29 PM
99bft's Avatar
Thanks
Thats exactly what it does and helps to keep it cooler. All externally mounted expansion valves (outside of the evaporator case) should be wrapped to work properly. If you need any you can buy some from Napa its part #209491, it comes in a role
99.5 F350 CREW CAB DUALLY 4X4, 4:10 (LS),ZF6 SWAPPED, RANCHO 2.5"LIFT, 305/70/16 NITTOS, RHINO LINED, B&W TURN OVER, TEKONSHA PRODIGY P3, MBRP 4" TURBO BACK, K&N CAI, PHP Hydra, Riffraff AIH DELETE, BILLET COMPRESSOR WHEEL, HPX,& "OCR", NON EBPV PEDESTAL, HIGH FLOW EXHAUST HOUSING, FOIL DELETE, ZOODAD, ISSPRO EV2 GAUGES, 6.0 TRANNY COOLER, EXTRA QUART POLISHED DIFF COVER, WARN HUBS, ARROWCRAFT SPACERS, ALPINE TOUCH SCREEN
OTHER TOYS:
65 N600 390
67 N1000 220 CUMMINS
99bft is offline
post #3 of 4 Old 08-21-2013, 09:15 AM
Quoted: 17 Post(s)
Cork insulation tape more that likely. I haven't looked at mine but it looks kinda like tar & spongy. We use it in the AC industry a lot for temporary repairs in insulation usually or around a valve that needs to be insulated.
By the way the lines in the back are liquid line (coming from the condenser to metering device & rear coil) & suction line. Suction line will be cooler
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #4 of 4 Old 08-21-2013, 05:15 PM Thread Starter
Christ Follower
Quoted: 14 Post(s)
thanks everyone
403,000
PHP Hydra
MBRP 4" Turbo Back
Firestone Ride Rite
Derale Atomic Cool
