- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
I can definitely Vouch for the truck running horribly. It really sounds like it has a miss, i dunno any other way to explain it other then at idle, it creates the same sound that a gasoline engine makes when its misfiring. If that makes any sense. Which in turn, would leave me to think you have injector problems. Could all of these problems be related tho? As in there's one thing causing all of it? I.E. Missfire sound, Low Oil Pressure, and Low ICP Just thought i'd add that too the pot also |
| Sponsored Links |
injectors, fuel, hpop/icp/ipr. List is long. Address the oil issue first. |
Simple example, let's say you have an injector with a clogged up (yes they do clog up, and no, injector cleaner will not fix this) or damaged nozzle, the fuel wont' be the same as the other cylinders. |
right, I see. not as much fuel or none at all geting into the cyl causes misfire, and high egts too huh? fuel is not there to keep the cyl walls cooler.
| Sponsored Links |
