  #21 (permalink)
Old 05-16-2008, 09:12 PM
Dirk Dirk is offline
Diesel Innovations
I just thought of something, did you fix the oil leak that you posted about awhile back? If you did, where was it? If you didn't, have you figured out where?
  #22 (permalink)
Old 05-16-2008, 09:45 PM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
No, I havent located it. I am finding small oil drips comming from under the valvecover gaskets. but I am not sure thats the major leak. Its comming from the back of the engine somewhere. I dunno from top or the bottom. All I know is the valley is dry, and so is the front of the engine. I am thinking its still the oil pan gasket and I cant stop it, cause where its leaking is the "U" in the back, between the block and the torque converter. you know where i am talking about? I cant get the permatex to stick there to seal it, plus its tight between the TC and the pan.
Also, I am leaking trans fluid from somewhere in the front of the truck near where the hard lines meet the rubber lines.
  #23 (permalink)
Old 05-16-2008, 09:49 PM
Diesel Innovations
As a LAST resort, pull your trans. You may be leaking from the rear plug of the block. That would cause low oil pressure.
That is a worst case scenario.
  #24 (permalink)
Old 05-16-2008, 09:52 PM
Diesel Innovations
It's in the cam area, I'm reading an obscure article. Never seen this first hand.
  #25 (permalink)
Old 05-16-2008, 09:53 PM
I have heard of that. I was hoping not to have to do it. But I think my trans is slipping anyhow. FCK! when it rains it pours! I may just look for a good rebuilt one near me. I wont have the cash for a while, but its something to look for. I am afraid to change the fluid for fear of slippage afterwards.
  #26 (permalink)
Old 05-16-2008, 09:55 PM
Diesel Innovations
Sorry, it seems I never have good news anymore.
  #27 (permalink)
Old 05-16-2008, 09:58 PM
aint your fault! Just a very hard ridden truck and not well cared for, well, at least after 2001 it wasnt, or so it seems since theres no more info on the oasis
  #28 (permalink)
Old 05-16-2008, 10:00 PM
Diesel Innovations
How much oil are you losing?
I'm a bit concerned about the oil pressure and "reman" engine. How many miles do you drive a day? Is the low pressure always the same?
  #29 (permalink)
Old 05-16-2008, 10:04 PM
well, i lose maybe 1/2 quart a week. but I only drive it maybe 3 times a week, and not more than 50-60 miles a week as of right now. its a pretty serious leak!
Heres from 5 pulls on the dyno to give you a idea:
  #30 (permalink)
Old 05-16-2008, 10:09 PM
Diesel Innovations
Not as bad as I would have imagined. I'm out of ideas really. You have a lot of work to do.
I don't know if it's possible, but I'd start looking for a nice 97-00 short or long block. Build it up in your garage as you have money/time. It's what I'm doing... for completely different reasons.
