  #11 (permalink)
Old 05-16-2008, 08:07 PM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
Check valve is still there. That under the oil filter right?
How do you add extra to see about the pickup?
I dont know about the bearings. Only way to check them is tear down. am I right? willl an oil analysis prove anyhting?
  #12 (permalink)
Old 05-16-2008, 08:08 PM
how do you add extra! DUH!
no, what I meant, was how do I do the test? how much do I add, what do i look for?
  #13 (permalink)
Old 05-16-2008, 08:48 PM
Dirk Dirk is offline
Diesel Innovations
By the adapter? I can't remember the last time I was under the truck.
wait.. what?
yes sir, and I've never done an oil analysis. sorry.
And since you made me have a small stroke racing back to proof read what I said.. I'm going to post instructions on how to change your oil.
  #14 (permalink)
Old 05-16-2008, 08:51 PM
so Dirk, what do I look for when I add the extra oil. How much should it take when the stick is showing full?
I am assuming when I add oil, my pressure will come up IF my pick up is cracked or shot right? and if not I am back to square one. Oh, do i drain the extra oil out? I dont think it would be good having the overfilled oil in there.
  #15 (permalink)
Old 05-16-2008, 08:53 PM
and I do know about changing my oil thanks. HAHAHA!
  #16 (permalink)
Old 05-16-2008, 08:55 PM
Diesel Innovations
If it shows full, add a quart at a time. I've only had to add 2 before seeing oil pressure increase. It honestly depends on where the problem is on the pickup tube.. if there even is one.
  #17 (permalink)
Old 05-16-2008, 08:57 PM
gotcha. thanks Dirk! so, what should I see for engine oil pressure when its right?
  #18 (permalink)
Old 05-16-2008, 09:02 PM
Diesel Innovations
I don't remember off the top of my head, but I'd say at LEAST 18-20psi @ idle and in the high 40's to 60psi @ 2000rpm's.
I may be off, but I think I'm in the ball park.
  #19 (permalink)
Old 05-16-2008, 09:08 PM
Thanks for ALL your help dirk. If I ever meet you, I am buyin you a beer!
  #20 (permalink)
Old 05-16-2008, 09:10 PM
Diesel Innovations
It's good. Just pass along anything you learn to someone else.
