Sell or not to sell. Advice needed. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-19-2013, 05:21 PM Thread Starter
2002 F250 7.3 just hit 104k. I bought the truck about 2 1/2 years ago with ~70k on it or so. Love the truck and it's been good to me so far (knock on wood). Only thing I've fixed were minor oil leaks, passenger hub, and rear driveshaft u-joints ( which weren't even bad my squeaks ended up being a shock absorber).
Well the truck is almost paid off maybe another year or so, but lately i've been debating on whether or not to just sell it before it becomes a project. The truck looks great on the outside but underneath it looks like it's starting to show its age. I just had my buddy who's a body shop guy fix some rust spots on the rear fender then spray the whole bedside and it actually came out great. Today i noticed by bed is starting to rot through. Aside from this my driver door is starting to rust pretty bad on the bottom, but hasn't made it to the outside yet. Also my oil pan is starting to go ( already have a new one prepped with a special coating, just waiting for it to get bad, and my front axle seals are shot.
I do use the truck and love it. Im a marine mechanic and work at a marina on Long Island. I do lots of sidework and also buy and sell used boats, so I do get to pull with the truck quite often. I know the 7.3 isn't going to win any races (stock anyway) but I've gotten used to it and I like it. If I could go back, I probably wouldn't have went with a diesel as I think I could have gotten by with a newer gasser for the same price i paid.
That being said, I can do all the repair work myself both mechanic and fab work needed to fix the rust issues. Finding free time to work on it seems to be my biggest issue. My question is should I sell it while i can and get most of my money back and get a newer gasser while also getting stuck with another car payment. Or should i just keep the truck, take care of it as best i can and just run it into the ground?
Sorry for the novel just looking for some other peoples opinions.
Jason
02 F250 7.3 Ext. Cab Long Bed
6637 DIY intake, muffler delete, EBPV delete, 6.0 cooler, ISSPRO gauges
285/75/16 BFG a/t's
lakailimited06 is offline
post #2 of 3 Old 08-19-2013, 05:40 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
My opinion would be to use this truck as a work horse. Do what you can to stop or slow the rust but if you buy a new truck now you got higher payments on another truck that is being eatin alive.
Or buy a older gasser for work and cherry out your 7.3.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 3 Old 08-20-2013, 07:54 AM
Quoted: 6 Post(s)
Jason
My 02 has 183k on it and has had very minimal issues (knock on wood). I replaced the front Hubs,just did the rear brakes (new calipers and pads), and just normal maintenance (oil change, diff fluid change). I don't think your in for a world of repairs with your truck like you may think.
As for the rust - sand it down, put some Por15 on it and let it cure. Then re-paint your original color or if on the frame/underside leave it black. Then to protect it against the salt, apply Fluid Film in the spring and again just before winter. This will keep the salt from eating the metal away/rusting. I use my truck for plowing and the calcium chloride they use in my area causes rust on brand new cars. My truck(s) have held up great over the years using this method.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
