WTB-old style weld hub centric wheels - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-18-2013, 04:55 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Like title says. Apparentley weld used to make true 4.93 hub bore wheels for our trucks, but not anymore. Now they are like 5.00. So, I am wanting an old set if anybody has any or knows where to get them. I have tried ebay but never see any. Maybe im not using the right search lingo?? I'm wanting to do a 4" lift and 35's so they would need like 4"-4.5" of backspacing im figuring. I'd like a 16" or 17" wheel with just about any width. Thanks for any help. Maybe the new welds with 5.00 hub will work, i dont know? Yall chime in
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
post #2 of 3 Old 08-18-2013, 08:08 PM
codyryan07's Avatar
I had a set of 17x10 -24 offset with 4.5 backspacing (i think) weld rock crushers on a 4 inch lift. Gave it a wide aggressive stance, and only had to pull the fender lining back. Check out my sig pic. Now i couldn't tell you about the hub bore because they used a lug centric setup which is what most after market wheel companies do to keep a "universal" setup.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #3 of 3 Old 08-19-2013, 05:17 PM
kingbilly68's Avatar
Quoted: 2 Post(s)
From what I understand, you can run the newer style wheels with acorn style lug nuts. This makes them lug centric instead of hub centric.
[/SIGPIC]2001 F-250 ecsb 4wd auto 150,xxx miles. 6637 factory straight pipe. Amsoil bypass system. Triple Gauge Pod.
kingbilly68 is offline
