Oil on ICP sensor - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-18-2013, 05:39 PM Thread Starter
usteffenhagen's Avatar
Oil on ICP sensor
Title says it all. Pulled it the other day and it had oil all up in it. Need replaced? will the truck run better once it's replaced? Also, I'm going to get it from the dealership unless someone recommends otherwise
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 4 Old 08-18-2013, 07:23 PM
Quoted: 769 Post(s)
Yep, you need a new one. Sometimes you can get them at the international dealer a bit cheaper if you have one local. Also, if you can wait, the two Ford parts dealers on here give us discounts.
Corey@CNCFAB is offline
post #3 of 4 Old 08-18-2013, 08:56 PM
Quoted: 769 Post(s)
Fwiw a member has a new one in the "Swap Meet"
post #4 of 4 Old 08-18-2013, 09:25 PM Thread Starter
Ok great thanks for the tips ill check it out in the morning
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
