help lowering my EGTs - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-18-2013, 03:24 PM Thread Starter
tompa00's Avatar
Just like it says. What all can I do or add to get my egts down a bit.
2016 F350
Sota Novakane 20x10 -19mm
Bilstien Leveling Kit
AMP Research Steps
more to come....
tompa00 is offline
post #2 of 13 Old 08-18-2013, 03:30 PM
01Crewcab7.3's Avatar
Bigger intercooler, water, live tuning.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 13 Old 08-18-2013, 03:32 PM Thread Starter
tompa00's Avatar
Yea ive been looking at intercoolers. Any suggestions
2016 F350
AMP Research Steps
more to come....
tompa00 is offline
post #4 of 13 Old 08-18-2013, 03:40 PM
CSIPSD's Avatar
Whats high?
What are you trying to lower them from?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 13 Old 08-18-2013, 03:48 PM Thread Starter
tompa00's Avatar
Originally Posted by CSIPSD View Post
Whats high?
Around 1400. Not even in the pedal all the way. I do oilfield work and pull a trailer all over. Havent had a chance to see where they will hit when im hooked up yet. Regaurdless im just wanting info on what aftermarket equipment will help lower the egts. Plain and simple
2016 F350
AMP Research Steps
more to come....
tompa00 is offline
post #6 of 13 Old 08-18-2013, 03:54 PM
The cheapest and best solution is a cooling mist kit and just use water, no meth.
Tim
post #7 of 13 Old 08-18-2013, 10:15 PM
timmyboy76's Avatar
fix your exhaust and boost leaks.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #8 of 13 Old 08-18-2013, 10:43 PM
CSIPSD's Avatar
Your hitting 1400* on a regular basis?
As said above, you have boost and or drive pressure leaks, a brake draging or something...
I have no EGT issues with my current set up, 8800#, 230/100's... Even with my old 250/200's I never had EGT issues, would get a touch hot when pulling in the mountians, but a little RPM management would fix that...
Fix your issues, then worry about aftermarket stuff.
Joe
CSIPSD is offline
post #9 of 13 Old 08-19-2013, 08:57 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
As stated water mist or a bigger better turbo, IC won't help much but will help a little. ..or have your tuner defuel it as some do so you don't have egt issues. Big fuel and good tunes will make heat period no getting away from it.
CT Performance, Inc. is offline
post #10 of 13 Old 08-19-2013, 09:08 AM
What is your current setup?
zillafreak is offline
