Shifting - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-18-2013, 12:29 PM Thread Starter
Quoted: 4 Post(s)
Shifting
Hard Shift
My newly acquired 2000 F350 DRW has the 4r100 trany
with 176,000 miles.
When going into 4th it shifts hard and abruptly. If I anticipate
the shift and let off the throttle a bit it smooths it out a bit
1st to 2nd is smooth, 2nd to 3rd smooth but a bit more abrupt.
Any thing to be concerned about??
Fluid is not discolored at all. Truck bone stock and never chipped.
I'm running about 61 to 62 mph at 2000 rpms or so... is this a 4.10
rear end? No tag on it that I can see.
Thanks
Sundance58301 is offline
post #2 of 6 Old 08-18-2013, 12:51 PM
timmyboy76's Avatar
ya, those rpms and speed coincide with 4.10's.
With acquiring truck, i'd do a complete tranny flush, to rule ur out...
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 6 Old 08-18-2013, 01:20 PM Thread Starter
Quoted: 4 Post(s)
Thanks........
I'll set up a trany flush, fluid looks good but a cheap
thing to do regardless.
post #4 of 6 Old 08-18-2013, 02:35 PM
usteffenhagen's Avatar
Are you sure a tranny flush is a good idea with those miles and you don't know if a flush has ever been done on that truck
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #5 of 6 Old 08-18-2013, 02:56 PM
I know near to nothing about automatic trannys because I have never owned one. My uncle has a 94 f-250 but with the E40D tranny and he had a problem with it shifting abruptly and somewhat violently into every gear. He was told to try disconnecting the battery for a certain amount of time to reset the computer, so he did and it worked. The tranny shifts normal and smooth now. Because yours shifts hard into only one gear, I'm not sure if this would work but since it doesn't cost you anything it might be worth a try.
99' Powerstroke is offline
post #6 of 6 Old 08-18-2013, 06:20 PM Thread Starter
Quoted: 4 Post(s)
Ahhh the trany flush controversy...
The battery disconnect is worth a shot, thanks
