transmission cooling - Ford Powerstroke Diesel Forum
post #1 of 16 Old 08-17-2013, 09:06 AM Thread Starter
aint no f ing hemi's Avatar
just a curiosity tossed out to some of you guys that know more than me: we all know a cool transmission is a happy transmission, but is there a point where there's too much cooling occurring? is there a problem with running too many coolers? is there "too cool" of an operating temp? what do you think?
1999.5 f250 auto 4x4 cc long bed
diy intake
ccv mod
18k mod
zoodad mod
aint no f ing hemi is offline
post #2 of 16 Old 08-17-2013, 09:13 AM
Quoted: 17 Post(s)
Feedback Score: 3 reviews
i know that too many coolerS can affect cooling because the pump is not strong enough to push the fluid through. all the newer trucks run the tranny fluid through the radiator to heat the fluid up in cold weather, so yes you can get to cold
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 16 Old 08-17-2013, 09:23 AM
I just installed a second cooler and now the power steering and brakes are acting all goofy. Very stiff at idle and from a stop. Once I get moving they seem better. I wasn't expecting that. I lost a little fluid when I switched the lines but maybe a pint total. Seems like a trivial amount when you figure the total volume.
Any ideas?
The Crusher
Crusher23 is offline
post #4 of 16 Old 08-17-2013, 09:35 AM
I should have said this is a 2003 F350 with a 7.3l
post #5 of 16 Old 08-17-2013, 09:47 AM
CSIPSD's Avatar
Are you sure you added a cooler to your tranny and not to your PS lines? Take a picture of how you tied your lines in...
They are completely different systems.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 16 Old 08-17-2013, 10:01 AM
I'll get a picture posted but the tranny cooler is a small radiator in front of and at the bottom of the main radiator. I don't think the power steeriing has such a system inline.
In the picture you can see the tiny factory cooler and just the bottom of the one I got from a 1997 F250 7.3l.
Thank you for the help. It is greatly appreciated.
post #7 of 16 Old 08-17-2013, 10:03 AM
I'm not finished with the install yet. I was just running around the block to check the lines for leaks.
post #8 of 16 Old 08-17-2013, 10:04 AM
CSIPSD's Avatar
Yup... You tied into the factory Power Steering cooler...
Please disconnect it.
If your truck is factory it does not have an air to oil cooler. It only has the water to oil cooler. There should be two 3/8" lines coming to the bottom of the radiator, those are your trans cooler lines.
Joe
CSIPSD is offline
post #9 of 16 Old 08-17-2013, 10:20 AM
I guess I shouldn't believe my brother-in-law.....the mechanic...... anymore.
I will correct the problem.
Thank you!
post #10 of 16 Old 08-17-2013, 10:25 AM
hansel's Avatar
Quoted: 100 Post(s)
CSIPSD
So the 2003 models year does not have a air/oil cooler???
Crusher23 that tiny little cooler is the ps cooler, the tranny cooler will fit between the A/C and the inner cooler, mine was about the size of a computer keyboard but I upgraded too the 6.0L cooler, it's huge when you compar the two together.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
