Edge Evolution, Valve Body?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-15-2013, 05:40 PM Thread Starter
jpalma's Avatar
Alright first of all I know the general opinion on this tuner on here is not liked as much as custom tunes. I got a good deal on it and have read plenty of positive things to give it a try, so its going on the truck. I know with the added power can cause increased trans temps, there is a feature on the tuner to turn down or up line pressure. I want to give my trans as much help as I can, should I put a valve body in as well to get more fluid flowing? I have read that the tuner adding pressure and the valve body adding pressure may be a bad combo? Thoughts???
2000 F250 Crew Cab, 366,500miles
,6637,Foil delete, Smoked Cab lights, Bed Liner Rockers, Muff. Delete,08 DIff Cover, 50 Gal Transfer Flow Tank
jpalma is offline
post #2 of 5 Old 08-15-2013, 05:45 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
which evolution is it? mine had pretty good trans tuning along with the ecm tunes..
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #3 of 5 Old 08-15-2013, 05:51 PM Thread Starter
jpalma's Avatar
Its the 15001. So you ran just the tuner on the stock trans? Any info on whether the valve body would be good addition or hurt things or a waste of money.
jpalma is offline
post #4 of 5 Old 08-15-2013, 10:46 PM
I've got the CTS, and it doesn't offer any options on ramping line pressures... I'd get a bts or a john woods. Cheap insurance compared to a 3k$ trans rebuild... I try to use my tunes as little as possible. When I do use the edge tunes if I'm going on a highway trip I turn it to extreme (best mpgs?) And in the city I use the stock mode (prolong tranny life).
Anyway, a little extra flowing, higher pressure trans fluid certainly can't hurt!
'01 7.3L PSD SCLB
Rubber:Ballistic Jester 18x9, 325/65/18 Falken Wildpeak A/T's << LOVE THEM!!
Motor:CCV mod, Zoodad mod, Edge Evolution CTS, Coolant Filter, Cat ELC, Dual Optima Yellowtop Batteries, 6697 mod
Suspension: Polyurethane sway bar link kit, 6" lift
Naterenfo1 is offline
post #5 of 5 Old 08-17-2013, 07:50 PM
I have the 15001.you gotta toy with the shift firmness a little.i messed around with mine and got some help from another guy and got it dialed in really nice.i let mine set on 1 for now just for the boost in towing power.once I need a tranny rebuild then ill set it on 2 for towing.
adams01 is offline
