7.3 Timing - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-12-2008, 07:37 PM Thread Starter
Fast73Excursion's Avatar
7.3 Timing
What exactly controlls the timing on the 7.3? Is there anything? I am relatively new into this serious stuff and curious.
2000
Excursion 2wd PSD
140 Chip
Cold Air
4" SS Exhaust
Needed:
Turbo Parts (1.0 Exhaust Housing and Wicked Wheel)
Fast73Excursion is offline
post #2 of 13 Old 05-12-2008, 09:55 PM
99bigred's Avatar
i think it is just the CPS that sends a signal to the ECU.
early 99 f-350 7.3 6speed crew cab
banks exhaust, chip, big head, exhaust houseing
and wheel
Ford AIS intake
5.5" fabtech lift w/ 35x12.50/18's
99bigred is offline
post #3 of 13 Old 05-13-2008, 04:24 AM
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
IDM probably has something to do with it.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #4 of 13 Old 05-14-2008, 06:51 PM Thread Starter
I was just thinking...Bad, I know! on a gas burner, you can buy a MSD Retard control that is basically a turn dial, that the driver can turn, to add or remove timing to the engine. Is there anything like this for the PSD??? Again, bad thoughts!!!
2000
Excursion 2wd PSD
140 Chip
Cold Air
4" SS Exhaust
Needed:
post #5 of 13 Old 05-14-2008, 06:57 PM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
cam sensor reads top dead center , nothing like a gas engine the way its timing is read , the cam sensor reads the gear on thge cam,sends the sigal to the pcm, pcm takes readings from that icp pressure and other sensors to establish fuel pulse width , which is also sent to idm to fire injectors , you can buy a dial controller that ties in with the icp sensor to adust fuel timing on a powerstroke, what would be the reason to want to do that
ITS STOCK
SCUFFY828 is offline
post #6 of 13 Old 05-15-2008, 01:53 PM Thread Starter
I just am looking for a way to pop my injectors a little earlier...
2000
Excursion 2wd PSD
140 Chip
Cold Air
4" SS Exhaust
Needed:
post #7 of 13 Old 05-15-2008, 06:37 PM
<<---"Shadow"---
sea71's Avatar
ENGLISH dude!!! ENGLISH!!
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #8 of 13 Old 05-15-2008, 07:32 PM
Is it even worth it???
ABOBB's Avatar
What's wrong Shane... I understood exactly what he said!!!!
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
post #9 of 13 Old 05-15-2008, 07:32 PM
planeoldguy's Avatar
Ingrish?
7.3, Auto., 4x4, 6637, Straight Piped Stock Exhaust, WW, Foilgone.
planeoldguy is offline
post #10 of 13 Old 05-15-2008, 07:38 PM
RedMule's Avatar
I'd be curious to know why to this???
01 LWB CC SRW 4x4 7.3 auto
Stage II's,HPX, In tank and pre-pump mods,regulated return
AFE stage II,Garrett BB Turbo,4" turbo back, ITP overboost annihilator, 10 pos. DP Tuner,
Motor and tranny rebuilt. forged rods,Mahle pistons, all balanced, new valves,Comp 910's,C/M P-rods,ARP Studs , homemade AIH delete kit, twin TRU-Cool tranny coolers,Ride-Rite air bags B-D X-Monitor
Don't worry about the Mule, just load the wagon.
RedMule is offline
