OBS to SD: Found a 2000 XLT Manual/single cab - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-14-2013, 02:05 PM Thread Starter
USAF-FD-NJ's Avatar
Hello all,
I found a 2000 F350 XLT Manual trans single cab its red. Has normal rust about rear fenders, looking to fix/replace, tailgate has rust will need replacement has slight but not bad under rust, front bumper bumped, grill is cracked, headlights fogged, interior practically mint, has 117,000 miles, batteries need replacement. Owner replaced oil pan.
What would your price be? He is asking $10,500
USAF-FD-NJ is offline
post #2 of 12 Old 08-14-2013, 02:30 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
thats a lot of stuff to fix, and then repaint.and that costs money.
id say like 7.5-9k unless the other guy is fixing everything before he sells it.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 12 Old 08-14-2013, 07:01 PM
Cummins_Killer's Avatar
Around 8.5-9k
Cummins_Killer is offline
post #4 of 12 Old 08-14-2013, 07:59 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I'd be looking to pay less than that... 7500 or even lower.
I bought my truck, a 1999 f250 lifted 6", never seen salt so 99% rust free, new transmission, lariat leather seats swapped in, 212000kms, DP tuner and gauges all for 6000$
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 12 Old 08-14-2013, 08:46 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
How did he replace the oil pan? The right way?
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #6 of 12 Old 08-15-2013, 02:01 PM
Quoted: 249 Post(s)
paint and body work is not cheap. could end up being THOUSANDS of dollars.
does he have any maintenance records?
post #7 of 12 Old 08-15-2013, 02:15 PM
BSkopnik's Avatar
I second this. This could be the yes/no factor.
Sent from AutoGuide.com App
02 F350 CC LB 4x4 Lariat
Done: K&N CIA, Torklift Camper tie down system, Firestone Ride Rite Air Suspension(Dual guage control, w/ reservoir tank), Autometer 3 Pillar guage(Boost,EGT,Tranny Temp), Vision Type 81 19.5" w/ Goodyear G622 RSD 245/70r19.5 LRG, 03-07 power/heat/light mirror conversion, Sinister Coolant Filter kit.
ToDo: Powerslot Cryo rotors, Hawke SD pads, 6.0L Tranny Cooler, Oil Temp/Pressure, Fuel Pressure and Diff Temp guages.
BSkopnik is offline
post #8 of 12 Old 08-15-2013, 02:20 PM
schlutzer's Avatar
Quoted: 18 Post(s)
X3 the right way being motor pulled, flipped upside down, and the pan re glued.
post #9 of 12 Old 08-15-2013, 05:18 PM
BSkopnik's Avatar
That be it. I've heard of the front crossmember being cut to get pan dropped. Other way lifting the motor not pulling it putting new pan on. Then sealing the pan with motor upside right. Never get the proper seal. Chances of leak are right there.
BSkopnik is offline
post #10 of 12 Old 08-15-2013, 07:55 PM Thread Starter
USAF-FD-NJ's Avatar
hmm, not sure I will contacting him this weekend. So proper way to pull the motor and flip it and re glue it or replace and glue it....?
I was going to offer $6,000 my top would be $6,500
