DIY Bellowed Pipes?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-14-2013, 01:56 PM Thread Starter
I ran across a guy on here that bought some bellows and welded them onto the stock up-pipes. Has anyone else tried this? Has anyone tried flexible exhaust pipe? Any advice would be helpful. I will keep you updated.
mram10 is offline
post #2 of 9 Old 08-15-2013, 05:01 PM
Quoted: 17 Post(s)
I'd make my own if I could find bellows. Although my up pipes are not leaking I feel they will at some point.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #3 of 9 Old 08-15-2013, 08:36 PM Thread Starter
I bought some bellows off of Summit for $29 a piece. We are going to give it a try. Still appreciate any info from
mram10 is offline
post #4 of 9 Old 08-16-2013, 07:01 AM
timmyboy76's Avatar
its the posititioning of the bellows that are where people will have problems. Without knowing exactly where to weld the inserts in, its a guess game, that is, unless the tranny's out and have a clear look as to where the placement should be.
If going to try, use these...http://www.summitracing.com/parts/vpe-40055s
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 9 Old 08-16-2013, 07:08 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
DIY answer...DIY (drive it yourself) to an IH dealer and buy one ...
but seriously, with the abuse they take (heat/vibration) Id just buy them and be sure I only have to do it once
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #6 of 9 Old 08-16-2013, 09:02 AM
Quoted: 134 Post(s)
Feedback Score: 3 reviews
It can be done, have a Read thru this -> Homemade Bellowed Up Pipes Input
NoRalPh is offline
post #7 of 9 Old 08-16-2013, 09:07 PM Thread Starter
Those are the bellows I bought. Thank for the input guys. When I succeed, I will do a write-up with pics maybe a video Anything is possible.
mram10 is offline
post #8 of 9 Old 08-16-2013, 09:13 PM Thread Starter
mram10 is offline
post #9 of 9 Old 08-16-2013, 09:28 PM
CSIPSD's Avatar
I've built two T4i kits with bellows.
Cant see where it would be hard to weld a couple bellows in.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
