***School me on Valve Bodies*** - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-14-2013, 11:49 AM Thread Starter
hansel's Avatar
Quoted: 100 Post(s)
So I'm one of those type of guys that reads a ton about something before making a choice, so now I'm in the market for a valve body. I've done some searching and found that John Woods,BTS, and Gregg Evans all make a great product. My question or question's are how complex is it too swap one out??? I'm fairly good with a wrench, but the tranny seems alittle scary too me other than changing the fluid. Another question, whom is really the best?? I'm looking for replies on guys that have actually had too upgrade thier valve bodies.
So I'm looking for information
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #2 of 10 Old 08-14-2013, 12:00 PM
I would like to know this too. i assume all are better than stock.
could some give a break down of the bodies with price compared to reliability and performance.
Thanks
zillafreak is offline
post #3 of 10 Old 08-14-2013, 12:14 PM
Quoted: 3 Post(s)
Its relatively easy to swap, just drain the pan, drop the pan, undo the valve body bolts and don't mix them up, change out trans filter while in there, reinstall new one, torque to spec, put pan back on, fill and go. I bought a john woods one, but found out afterwards that bts credits you if you buy his trans down the road, just something to keep in mind if your planning on upgrading later on.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #4 of 10 Old 08-14-2013, 12:17 PM
LvGolfer962's Avatar
Valve bodies are very simple to swap out
Drop the fluid and pan
remove the 13 or so bolts
and install the new one
iirc its like 45 inch pnds for the bolts
LvGolfer962 is offline
post #5 of 10 Old 08-14-2013, 12:21 PM
Mitch
thebierguy's Avatar
Quoted: 93 Post(s)
http://www.powerstroke.org/forum/7-3...e-up-pics.html
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #6 of 10 Old 08-14-2013, 02:50 PM Thread Starter
hansel's Avatar
Quoted: 100 Post(s)
Originally Posted by thebierguy View Post
Thanks man
Someone said there are some check ball's, is that true???
Great right up
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #7 of 10 Old 08-14-2013, 03:28 PM
Quoted: 897 Post(s)
Feedback Score: 3 reviews
Originally Posted by hansel View Post
Thanks man
Great right up
Inside the VB yes. But you won't be getting into that. Its pretty easy. Just as easy as removing the pan then putting it back on.
Corey@CNCFAB is offline
post #8 of 10 Old 08-14-2013, 05:49 PM Thread Starter
hansel's Avatar
Quoted: 100 Post(s)
Oh ya U can do that then, I really would like too say "Thanks" you and thebierguy have been a great help
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #9 of 10 Old 08-14-2013, 06:53 PM
Mitch
thebierguy's Avatar
Quoted: 93 Post(s)
No problem!
Mitch
post #10 of 10 Old 08-15-2013, 06:09 AM
Quoted: 897 Post(s)
Sure thing. Its still fresh in my head since I changed out my VB plate to up my shift pressures. The link didn't work for me so just make sure you remove the little filter on the VB before you remove all the bolts. Or you can go to BTS website and download their PDF file.
