Is this the right truck - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-14-2013, 04:31 AM Thread Starter
jackfrazee's Avatar
Howdy All-
I'm still in search of my first diesel and have another potential candidate. Yesterday I looked at a 2002 crew cab with a 166K miles for 12K. Overall the truck looks clean, a few dents, dings and scratches. The engine compartment looked clean and underneath there doesn't appear to be any major leaks. The tires probably have 1 winter left. The bed of the truck indicated the was not a 5th wheel or goose neck set up, but there is a break controller in the cab which I would assume there has been some bumper pulling.
I didn't have time to drive the truck yesterday but when I started it there were no check engine or O/D lights. In fact, after starting all lights went out as they should. At a stand still I shifted through all the gears, which I could barely tell when it shifted. The trans fluid smelled clean and looked light red.
The CARFAX identifies that the truck has had 6 owners, is this a concern?
By chance can anyone run an OASIS? VIN: 1FTNW21F12EC71349
View all Englewood Denver Used Cars | Best Car Buys III 3
Do you think this is a fair price?
Do you think I should have a shop look at it? The dealer being out of town may make this a bit difficult.
Any other thoughts, comments, suggestions?
Thanks
jackfrazee is offline
post #2 of 10 Old 08-14-2013, 11:52 AM
COONASS
WHAT HAPPENED's Avatar
Source : Vehicle History Report VSVIN.info
78-89 it got an 80...
What is your location? CO
http://www.autotrader.com/cars-for-s...Index=11&Log=0
WHAT HAPPENED is offline
post #3 of 10 Old 08-15-2013, 05:03 PM Thread Starter
jackfrazee's Avatar
Took the truck to a diesel shop for a pre purchase inspection, they found about $5000 worth of repairs. Used car lot only budged $500. The search goes on.
post #4 of 10 Old 08-15-2013, 07:35 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
I'm curious to know what these repair items were. Shops charge $100+/hr just in labor so of course it's going to be ridiculously expensive.
Depending on your capability, it could all be DIY.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #5 of 10 Old 08-16-2013, 03:17 AM Thread Starter
jackfrazee's Avatar
Some of the items: turbo feed tube, front inner axle seal, water pump.
I've maintained my gas vehicles for years but being new to diesels I'm a bit tentative.
On the up side I'm heading to look at a 2001 f250 with 156k miles this afternoon.
Is $12k too much if theres not much wrong?
post #6 of 10 Old 08-16-2013, 05:57 AM
Quoted: 19 Post(s)
Each truck is a case by case basis. Read and follow up on a search of "7.3 What to look for" (phone will not allow me to paste the link) but if it's in decent condition, $12k isn't unreasonable.
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #7 of 10 Old 08-18-2013, 04:11 AM Thread Starter
jackfrazee's Avatar
Once again the 7.3L I looked at was misrepresented by a "stock" photo. This guy took a crew cab photo and posted it as has truck, which was a supercab. Arg!
I did end up buying a truck this weekend. I ended up with a 1-owner fleet 2005 F250 Crew Cab Lariat. The hitch receiver was never used and no fifth wheel.
I guess I need to hop on over the 6.0L threads.
Thanks All.
post #8 of 10 Old 08-18-2013, 04:33 AM
Quoted: 19 Post(s)
Congrats on your purchase! Post up some photos
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #9 of 10 Old 08-18-2013, 04:50 AM Thread Starter
jackfrazee's Avatar
Here are a few pics
post #10 of 10 Old 08-18-2013, 06:31 AM
Quoted: 19 Post(s)
That's a great looking truck Enjoy
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
