Climate control - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-13-2013, 11:02 AM Thread Starter
Climate control
I have a 2000 f250 and my a/c-heat blower does not come out of the vents no matter what selection I stick it on it only blows out the defroster does this mean my switch is bad or is there something it could be. Thanks
2000 f250 7.3 airade intake 4" mbrp straight pipe bully dog diesel tuner gt with Harley-Davidson f350 interior
boboridesthefa is offline
post #2 of 17 Old 08-13-2013, 01:20 PM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
You have a vacuum leak somewhere. Defrost is default setting
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 17 Old 08-13-2013, 03:02 PM Thread Starter
Where should I look
post #4 of 17 Old 08-13-2013, 03:50 PM
Quoted: 16 Post(s)
have you worked on or changed anything lately?
post #5 of 17 Old 08-13-2013, 04:09 PM Thread Starter
Just worked on the front end did all new hub bearing and all new ball joints and put lift on
post #6 of 17 Old 08-13-2013, 04:25 PM
Quoted: 16 Post(s)
you may have a leak in the frontend. i changed out the lockouts to manual ones and did not block off vacuum lines. mine only works on defrost when i use 4x4.
post #7 of 17 Old 08-13-2013, 04:27 PM Thread Starter
I have Manual locking hubs and and befor I stated working on it the nuckle vacuum fitting was broke off and missing the line on one side and I replaces both sides with all new seals in the hubs and nuckle
post #8 of 17 Old 08-13-2013, 04:30 PM Thread Starter
Should I try to plug the lines going to the hubs and see if it works sound like a good idea?
post #9 of 17 Old 08-13-2013, 06:10 PM
Quoted: 16 Post(s)
did you switch to manual locking hubs? if not and you plug the lines then your lockouts will not work(unless you manually do them). it should only leak there when in 4x4.
post #10 of 17 Old 08-13-2013, 06:19 PM Thread Starter
It had the Manuel locking hubs on there already
