4x4 not engaging - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-12-2013, 09:16 PM Thread Starter
agriffin's Avatar
4x4 not engaging
Truck had ESOF but hubs were replaced with warn manual hubs. No dash light or anything. All the fuses and relays test good. Was wondering if there is anyway to determine if it is the transfer case motor or the 4x4 actuator?
2001 f250 7.3 PSD
4" Diamond eye exhaust
DIY 6637
Isspro ev2 gauges Boost,Pyro,trans temp
PHP Pheniox
Boost fooler
Firestone airbags
agriffin is offline
post #2 of 10 Old 08-12-2013, 09:58 PM
BSkopnik's Avatar
Could be a few things. Check the harness that goes into the transfer case. I know it will sometimes get loose and not signal correctly. Also a possibility of a GEM module, father in laws 01 350 had a GEM crap out and he lost his 4x4. Check for power at 4x4 switch? Any codes tripping? If you can get a scanner you can watch the position of the transfer case during different positions (2,4,4L). Good chance that a code will be tripped but no CEL light.
Sent from AutoGuide.com App
02 F350 CC LB 4x4 Lariat
Done: K&N CIA, Torklift Camper tie down system, Firestone Ride Rite Air Suspension(Dual guage control, w/ reservoir tank), Autometer 3 Pillar guage(Boost,EGT,Tranny Temp), Vision Type 81 19.5" w/ Goodyear G622 RSD 245/70r19.5 LRG, 03-07 power/heat/light mirror conversion, Sinister Coolant Filter kit.
ToDo: Powerslot Cryo rotors, Hawke SD pads, 6.0L Tranny Cooler, Oil Temp/Pressure, Fuel Pressure and Diff Temp guages.
BSkopnik is offline
post #3 of 10 Old 08-13-2013, 12:13 AM
I would clean the connection at the transfer case motor like ^ said.
That has been my problem a couple times, especially if you have never cleaned it or do a lot of offroading.
Then check to see if there is power getting to the motor on the transfer case if that doesn't work.
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #4 of 10 Old 08-13-2013, 06:54 AM Thread Starter
agriffin's Avatar
the dash switch is good. I checked the T-case motor to make sure I didn't break any wires but didn't clean them. is there any special way to clean? use dielectric grease?
2001 f250 7.3 PSD
DIY 6637
PHP Pheniox
Boost fooler
Firestone airbags
agriffin is offline
post #5 of 10 Old 08-13-2013, 09:10 AM
BSkopnik's Avatar
Di-electric grease will work. It'll help with a water resistant seal too. When you say switch is good. You mean you have power? Another thing with the switch is the switch itself could be out. Another thing the scanner could tell you is the 4x4 switch position. Last post of mine talking about the actuator I meant the contact plates in the transfer case. So with the scanner you could watch the state of the contact plates.
BSkopnik is offline
post #6 of 10 Old 08-13-2013, 11:46 AM Thread Starter
agriffin's Avatar
I took my switch and put in in my friends 03 and it shifts his truck thru 2,4,4l.
2001 f250 7.3 PSD
DIY 6637
PHP Pheniox
Boost fooler
Firestone airbags
agriffin is offline
post #7 of 10 Old 08-13-2013, 06:34 PM
BSkopnik's Avatar
Try swapping transfer cases see what happens? If you have that easy access to test with. If yours works in his and his still doesn't work in yours. I'd almost be inclined to say GEM. Can try some pinpoint tests for the esof, but a code could narrow it down.
BSkopnik is offline
post #8 of 10 Old 08-13-2013, 08:07 PM
BSkopnik's Avatar
I dug up the pinpoint tests for the ESOF on the 01. Quick search on google merrited them.
Here is the Pinpoints
Wiring Diagrams for ESOF
GEM Removal and Installation
Maybe this can help you out. Cheers.
BSkopnik is offline
post #9 of 10 Old 08-13-2013, 09:37 PM Thread Starter
agriffin's Avatar
thank you for then links BSkopnik. Do you have to change the t-case fluid to swap the motors or actuators out?
2001 f250 7.3 PSD
DIY 6637
PHP Pheniox
Boost fooler
Firestone airbags
agriffin is offline
post #10 of 10 Old 08-13-2013, 10:00 PM
BSkopnik's Avatar
Nope. Just unbolt and pull off for the swap to test. Almost like a starter
BSkopnik is offline
